How can I improve my solution for this 2nd Order D.E.?
  • Thread starter Thread starter gbacsf
    2nd order
gbacsf
I'm have a lot of trouble trying to find the general solution to the following D.E.
y'' + 6.4y' + 10.24y = e^(-3.2x)
I get the homogeneous solution as
C1*e^(-3.2x)+C2*x*e^(-3.2x)
and the particular solution as 0
So a general solution of
Y=C1*e^(-3.2x)+C2*x*e^(-3.2x)
I know my solution is not right, there is some trick to it, any help?
Gab
You DO mean the diff.eq y''+6.4y'+10.24y=e^(-3.2x), right?
Ops, yes I do.
The reason you obtained 0 as your particular solution in your approach is because the inhomogeneous term is also a solution to the homogeneous equation.
What should you do in that situation?
uh? Variation of parameters to get something like
Yg=u1y1+u2y2+c1(x)y1+c2(x)y2
where Yh= u1y1+u2y2
and Yp=c1(x)y1+c2(x)y2
So...
Yg= u1*e^(-3.2x)+u2*x*e^(-3.2x)+0.5*(X^2)*e^(-3.2x)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
