Proving Equivalence of Operations on Equivalence Classes
mossfan563
Prove that if (a1, b1) ~ (a2, b2) and (c1, d1) ~ (c2, d2), then (a1, b1) + (c1, d1) ~ (a2, b2) + (c2, d2)
and (a1, b1) \bullet (c1, d1) ~ (a2, b2)\bullet (c2, d2).
Let [a, b] denote the equivalence class with respect to ~ of (a, b) in Z x (Z-{0}), and define Q to be the set of equivalence classes of Z x (Z-{0}).
For all [a, b], [c, d] in Q define [a, b] + [c, d] = [(a, b) + (c, d)] and [a, b]\bullet [c, d] = [(a, b) (c, d)]; these definitions make sense, i.e., they do not depend on the choice of representatives.
(a, b) + (c, d) = (ad + bc, bd) and (a, b) \bullet (c, d) = (ac, bd)
(a, b) ~ (c, d) if and only if ad = bc
I tried using those definitions.
I know you have to assume that (a1, b1) ~ (a2, b2) and (c1, d1) ~ (c2, d2).
But I get stuck afterwards. Where do I go from there? Do I need something more?
and (a1, b1) * (c1, d1) ~ (a2, b2) * (c2, d2).
Are you asking how to prove this?
Write down what (a1, b1) ~ (a2, b2) means and what (c1, d1) ~ (c2, d2) means; these are given.
Write down what (a1, b1) + (c1, d1) is, what (a2, b2) + (c2, d2) is, and then what (a1, b1) + (c1, d1) ~ (a2, b2) + (c2, d2) means. This is what you must prove. The proof practically writes itself once you write down what these statements mean.
Repeat for *, which may require a tiny trick.
Write out your work for us and ask questions if you get stuck.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
15K
