When Does the Car Come to Rest Again?
  • Thread starter Thread starter MellowOne
    Rest Time
MellowOne
A car is stopped at a traffic light. It then travels along a straight road so that its distance from the light is given by x(t) = bt^2 - ct^3, where b = 2.30 m/s^2 and c = 0.120 m/s^3.
How long after starting from rest is the car again at rest?
dx/dt
The problem I'm having with this question is I can't figure out how you can find the deceleration after the car stops accelerating. I know at t = 0 the velocity is 0 m/s, at t = 5s the velocity is 14m/s, and at t = 10s, the velocity is 10m/s this means the car decelerated from t = 5s to t = 10s. How do I find the deceleration to find how long it took the car to reach maximum velocity assuming it's 14.0m/s to come back to rest?
Try using the fact that a=(delta v)/(delta t)
Ok, I got it...I just took the derivative of the distance formula which would make it into the velocity formula. Then I set the velocity equal to 0 and used the quadratic equation to find t.
Sounds right
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
