Attacking Einstein (and other pursuits)
  • Thread starter Thread starter Gorn
    Einstein
The discussion centers on the perception of physical constants, questioning their arbitrary nature and exploring the concept of parameter analysis in physics. It clarifies that while constants like the speed of light may seem arbitrary, they are defined within specific measurement systems, making the units themselves the arbitrary elements. The relationship between momentum (P), mass (m), and velocity (v) is examined, confirming that changes in momentum do correlate with changes in velocity, provided mass remains constant. The conversation also emphasizes the importance of correct unit usage in understanding these relationships. Overall, the dialogue highlights the foundational principles of physics and the significance of measurement systems in defining constants.
Gorn
Hello...
I have heard that the speed of light is 300,000km/s. Planks constant is another number and so on and so on and so on.
Alot of these numbers seem to be very 'arbitrary' figures... Is there a subject in physics called "parameter" analysis where the various arbitrary numbers and constants in physics are studied to give some understanding or reason for their magnitude?
Also, is there another area in physics that provides principled or theoretical or a logical foundation for the various terms in physics like ...m/s, kg/m/s etc.etc.etc. that were introduced in physics to formulate various theory's. Sorry.. a bit of a vague question.
* In the equation P=mv (which is the equation for momentum)...if I switch the variables around I get M=P/v...Does this equation mean that if there is a change in momentum there is a "direct - and exactly porportional change in velocity? Eg. If P= 5m/s v will equal 5m/s?
Thank you for any and all answers.
Bye
G.
The constants are not arbitrary, our units of measurement are the arbitrary units. You can set the speed of light to whatever you want, ~3.0e8 m/s or 1 something/something. But this reflects a change in your system of units.
The change in momentum is equal to force via Newton's laws. Force is the product of mass and acceleration, the latter describing the change in velocity over time.
The fundamental constants are overdetermined by many overlapping partially correlated precision measurements. A detailed discussion of the latest comprehensive least-squares fit can be found at
http://physics.nist.gov/cuu/Constants/RevModPhys_80_000633acc.pdf
A summary of the fundamental constant values can be found on pg 85 of the pdf.
Bob S
Your units are wrong, but the proportionality you refer to is there.
For example, if an object has a velocity of 9 m/s and a momentum of 100 kg m/s, then for the same object, its mass unchanged, if its new velocity were 27 m/s, then its new momentum would be 300 kg m/s.
This isn't a question about physics but a question about how to use fractions. In general, to say that A/B = some constant means that it's equally true to write that 3A / 3B is the same constant, or 94A / 94B = the same constant.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
