3D Thrust-Vectoring and Supercruise
  • Thread starter Thread starter EngTechno
    3d
3D thrust vectoring refers to the ability of aircraft to manipulate engine exhaust direction for enhanced maneuverability, allowing for improved turn and roll rates. Supercruise is defined as the capability to sustain supersonic speeds without the use of afterburners, although there is debate about its practical application in military aircraft. While some argue that afterburners are essential for achieving supersonic speeds quickly, others point to examples like the F-22 and MiG-31, which can supercruise without them. The discussion highlights the complexities of aerodynamic drag and engine design in relation to supersonic flight. Overall, thrust vectoring and supercruise are critical features in modern military aviation, impacting performance and tactical capabilities.
EngTechno
What is 3D thrust-vectoring and Supercruise ? I frequently see this terms in Military Fighter Aircraft data. I know nothing about it. Can you explain me in detail? Any website for it?
According to this page, supercruise means the "ability to... fly at supersonic speeds without using afterburners" (2nd paragraph).
Thrust vectoring is the use of flaps near the engine outlet to point the flow in a desired direction. This increases the possible turn and roll rates.
Here's a website with some pictures of 2D thrust vectoring. 3D just has side to side capabilities as well.
thrust vectoring can also be used to achieve vertical lift off, but unless it is truly essential to verticaly lift off the loss in efficiency when vectoring that much dose not make it worth the cost in efficiency
To some extent this is right.
Supersonic cruise requires the help of afterburners, no matter what.
There are no planes which can fly supersonically at full throttle with just engines alone?
What mechanism is preventing supersonic flight without afterburners?
Name an aircraft.
This site says that the Concorde uses afterburners in the transonic regime and then turns them off for supersonic cruising.
I'm not sure if it's accurate or not.
It's possible that fighter aircraft are engineered to rely on afterburners for supersonic flight, but I can't think of a reason why they'd be needed.
Heck, the X-43 doesn't use afterburners either, but it doesn't really apply.
Enigma, (sorry if this isn't your real name)
I can see your point of view towards afterburners, I suppose that you, just like I am, are worried about our environment. It's indeed very worrying.
However it is very hard to reach supersonic speeds without the use or help of afterburners. The reason I say this is because just like the concorde, fighter planes attempt and succeed reaching supersonic speeds as fast as possible.
If you think about it, a plane reaching supersonic speeds without the use of afterburners takes a long time. This would be extremely concerning towards fighter planes that have the goal of arriving at a place as quick as possible.
So concluding, the emphasis of using afterburners is in order to reach supersonic speeds as fast as possible. Ever wondered why the concorde used them? the promised 2h15m from EGLL (Heathrow) to JKFK (John Kennedy) would be dragged to at least 6 hours if the integration of afterburners never took place.
Daniel
Well, I'm an engineer. As an engineer, I'm always curious why things work the way they do, particularly aircraft (which isn't my area of expertise) and spacecraft (which isn't either, but I'm working on it...). I had never heard that there weren't any supersonic planes which did not rely on afterburners. Since you mentioned it, I wondered if you knew why there aren't any.
I'm sure that a bigger reason would be the tremendous increase in aerodynamic drag in the transonic regime. That drag decreases again once you go past Mach 1.3 or so. I still don't see why they'd need afterburners for supersonic flight.
faust9 said:
YF-23
Supercruise was a critereon for the design of the Advanced Tactical Fighter. I think that's where the term came from. The YF-23 was Northrup's entry into the design contest and Lockheed's was the YF-22. The YF-22 won and is now the F-22. It has supercruise and single axis (pitch) thrust vectoring.
Like enigma said, drag increases quickly in the transonic reason - this means that acceleration is pretty good right up until you get to mach 1.
There may be an exit velocity/nozzle shape issue with some engines.
Both thrust vectoring and supercruise are features of the Joint Strike Fighter (JSF). Thrust vectoring is what the AV8B uses to enable S/VTOL (as originally developed for the 'Harrier' on this side of the Atlantic). It also enabled the development (during the Falklands War) of a new tactic - 'vectoring in forward flight' (VIFFing) - to climb, brake and force pursuing enemy aircraft to pass on by and come into weapons range.
Supercruise is indeed the ability to sustain supersonic speeds without re-heat ('afterburners' on that side of the Atlantic). Do a google on 'JSF' for more information than you require.
That's where afterburners increase from MACH 1.00 to 2.00.
And Enigma... there are planes in which do not use afterburners to reach supersonic cruise however these fighter planes are rather new.
I think I explained why afterburners exist for supersonic flight. I'm sorry if you can't understand it.
Cool it, DM. We're all here to learn - even you.
The airfore recently messed up the definition of what supercruise meant to cover up the failures of the F-22
The real definition should be "the ability to cruise(cover distance economically) at supersonic speeds."
Not "supersonic flight without afterburners"
A real supercruiser in existence today would be the Mig-31.
Notice the fuel fraction of the Mig-31 compared to other fighters.
So pretty much discard the current USAF pushed definition of supercruise, it was done to coverup the failures of the ATF/JSF projects.
For a good overview of the F-22:
http://www.pogo.org/p/defense/do-000608-f22.htm
First for an unbiased description (not read the other posts)..
Supercruise - Is the ability to accelerate pastand maintain trans and supersonic speeds without the use of afterburners
3D-Thrust Vectoring - It is the ability to rotate the Engine outlets amonst a 360* axis which allows for greater turn Radii and improve strike and life capabilities such as on the ATF F-22 raptor JSF (usa).
NOw to READ the posts...
but not 3D thrust vectorin.. and it doesn't require the use of flaps to direct
the air a direction.. it has adjustable nozzles on the side.. such as on the Harrier Jump-Jet (britain)
Prove this... I have been taught and read that this is NOT true... link it please... if you COULD disprove it wiht a credible source.. please do, Becuz i have heard from an Air-Force Cheif (my Uncle) that this is NOT the case.. supercruise does NOT! require the use of afterburners
The use of Afterburners is NOT primarily to reach supersonic spees AFAP.. but yet to Break supersonic speeds efficiently (well more so than conventional jets). Afterburn'ing' is a method of injecting fuel into the exhaust to create more thrust which is needed to acquire trans-sonic speeds (above mach 1.5), in level flight. the Concorde did not use its after burners until mach .8 (atleast) or it would have been unreliable and inefficient. And yes the concorde did turn off its afterburners after supersonic flight, however this is because they did not need to maintain those speeds any longer, in fact they had to Deccelerate to sub-sonic speeds before entering into US air-space (which i believe is 150 NM off the coast). technoicaly you COLD cruise for awhile at super-sonic speeds afterturning off afterburners, howevere you CANNOT maintain those speeds...
done... finally... for now atleast
Trans-sonic is not above M#1.5. Trans-sonic is what happens near M#1 when portions of the airflow over the top of the wing reach supersonic speeds and form small oblique shock waves there. This increases drag immensely.
o sorry.. musta been thinking of somethin else.. ill look into it for what i meant..
Maybe you were thinking of hypersonic (M#>5)?
Welcome to the forums, BTW...
Always good to have another aero-head here! :biggrin:
Thx, no that's not what i was thinking of, but i can't find it anywhere.. I am sure it'll hit me. My uncle told me once and i looked it up somewhere, can't find it. I'll have to sak him next time i get around to it. I am 16 now and know way too much for my own good.. and I've wanted to fly and know why things fly for as ling as i can remember.. but that's the only thing wrong that i mentioned, because if I am wrong please do correct me, once again , I am only 16 but i still know alot, however I am sure i don't know as much as a lot of you guys, so I am here to help AND learn
Wrong. Just because you are above the mach doesn't mean you have to afterburn fuel. One has nothing to do with the other. Better engines, lighter aircraft. Hell, missles fly mach 2-4 without any kind of AB (or breathing air for that matter).
You don't really know what you are talking about, basing information you read in the news is never a very good idea. The F/A-22 can supercruise, which means to fly above mach without the fuel-guzzeling afterburners. As far as failures, the real failure was in congress. The real reason the cost of the plane is so high is they cut orders from over 750 to under 280. The coast of the actual plan hasn't gone up much more than inflation. But when you include development costs in the cost per fighter, the reduction of aircraft really makes an impact on per plane cost.
That's really the only major problem with the aircraft, cost per plane.
The major problem? I'd say it's the only good and decent thing about it. That way, perhaps, they won't make so bloody many of them.
Heck. The MiG 1.42 is still way cooler. And better, as it is very unlikley to ever fight in a real battle, thus saving hundreds or thousends of human lives. The main drawback with all machines of destruction is that they are nothing but machines of destruction, monuments of our evil and bloodthirsty souls. "If you don't want anyone to drop the bomb, don't build the bomb" is the way we should think, not "lets build the bomb before anyone else does" because maintaining the terror balance is the easiest way to put everything else out of balance. We waste far too much energy and money on increasingly advanced and ingenious ways to killing each other, instead of trying to live in harmony.
And peace.
As for the subject question i have two points:
1. I find it hard to believe that it would be impossible to construct a jet engine capable of supersonic flight without the use of an afterburner.
2. The mechanics of directing the thrust, may it be flaps or a moveable nozzle, is of no importance for the definition of "thrust vectoring".
Cheers.
I think you missed the point: the actual cost to manufacture a single plane is pretty low, but the R&D cost is high and fixed (its the same lump sum up front whether you buy 1 plane or 1000 planes), making the oft-cited "cost per plane" number highly misleading. Remember, the development of a plane takes upwards of 20 years and all of that is paid for before a single production aircraft is delivered.
Pulling some numbers out of the air, if R&D cost $1 billion and each plane cost $20 million to manufacture, the "cost per plane" of 10 planes is $120 and the "cost per plane" of 100 planes is $30 million.
Because of this, a tiny cost overrun or drop in funding results in a massive reduction in the number of planes built and a massive increase in the "cost per plane."
More:
The real problem here is the government procurement regulations. The process is so cumbersome that the F-22 has been in development since 1981(!) and is only just now entering service. Only 4 years of that ('86-'90) was from selection of the two teams to the first flights of the prototypes.
Contrast that with the F-117, which was developed largely without government obstruction since it was so secret few in government knew it existed. It started in 1975 with research into stealth, in 1976 Lockheed had a mockup undergoing radar testing, and by Feb, 1978 they had two flying prototypes (too small to be real combat aircraft). The F-117 itself began development in 1978, the first production plane was delivered in 1981, and the first combat unit was operational by '83.
Unit cost is listed as $45 million.
Okay. Great to know. How much is a F-16? An Apache chopper?
Still I think it is a waste of money. I don't want to guess how much of those AIDS brake drugs you could get for the price of one kickass fighter jet... or how many mountain gorillas you could save (probably more than there is alive today). Hope you don't think I'm way too much out of topic.
cheers.
Sometimes in photos of jet exhausts you can see dark and light vertical bands.
Is this a trick of the camera or sound waves or something else?
cheers.
It is off topic, but I'll answer: if the US military didn't exist, there would be no AID drugs because Hitler would still rule the world. War and the need to defend the US and the world are a fact of life, whether you like it or not and that means weapons are a necessary evil.
Could you elaborate? I'm not sure what you mean here.
I think I know what you're talking about here...
The exhaust gasses are exiting the engine nozzle at supersonic speeds and being dumped into stagnant atmosphere. So, the pressure difference causes a shock wave to form. These shock waves from the edges of the nozzle converge until they bounce off of each other and reflect. Then, the flow expands again until the flow bounces off the slip line created by the exiting gasses. The flow then reflects again until the waves bounce off each other again. This process repeats until enough energy is dissipated that the flow becomes subsonic. The dark and light bands you are seeing are due to the diffraction of light around the compression waves (higher pressure) and through the expansion waves (lower pressure).
Hope that explained it.
(See "Fundamentals of Aerodynamics" by Anderson for a more in depth explanation.)
  • #31
cheers.
F-16 are about $30M. And I love it when hippies talk of buying drugs (legal or not) and saving gorillas with the money. So what happens when we get our ass kicked in the next war? Think there will be any money left over for saving gorillas? Nope, it's called reparations.
Go invent somethign that makes you a lot of money and then you can save the rainforest or whatever you chose. It's the business of the government to keep us defended and provide basic social services. Not to save the gorillas in a country that produces as much coke as coffee.
Ranting here, sorry.
  • #32
sigma said:
The MiG 1.42 is still way cooler. And better, as it is very unlikley to ever fight in a real battle, thus saving hundreds or thousends of human lives. .
Hundreds of thousands huh? F/A-22 is a better plane than every MiG flying right now. The Su-Flaker can probably outfly the F/A-22, but doesn't have it's speed or stealth advantage and would most likely lose the engagement.
1. OK, but believe it. Most military jet engines actually push gas out at supersonic spesds, but the aircraft doesn't get above mach because of drag. The F/A-22 has two of the most powerful jet engines on it, hands down.
2. Wrong. Are you just trying to agrivate people?
  • #33
hi! i want to know...what are the measures taken for stealth in thrust vectored aircraft.
and is there anything called puff in thrust vectoring.
  • #34
Talking with an F-22 test pilot from Edwards gave me a lil insight into how the Raptor is able to attain supersonic speeds without the use of an afterburner. The F-22 initially climbs to an altitude between 40000 and 45000 feet. At this altitude the air is less dense, which produces less drag on the aircraft. At military (approx 70-80% max power) the F-22 goes into a shallow dive, increasing its speed past Mach 1 to approx Mach 1.5. Once the aircraft has pushed through the sound barrier the drag on the aircraft reduces, allowing military power to sustain its supersonic speed. The Raptor is then able to return to operating altitudes (30000 - 35000 feet) while remaining supersonic.
This method of supercruising is not necessarily an issue of having the required power to muscle through the sound barrier and increased transonic drag. It has been theorized that other aircraft (F-4, F-15, F-111, Eurofighter Typhoon, Rafale) may be able to "supercruise" using this technique. However, because I am not privy to how the other aircraft may or may not be able to supercruise I cannot comment on those. In several flight simulation games (Microsoft Flight Simulator, Janes F-15, and Lock-On Modern Air Combat) my friend and I have been able to attain supersonic flight without afterburners with an F-15 in the clean configuration and internal fuel only using the above mentioned technique. However, these are merely simulations and cannot be relied on as how actual aircraft may be able to supercruise.
  • #35
sigma said:
...and better, as it is very unlikley to ever fight in a real battle, thus saving hundreds or thousends of human lives. The main drawback with all machines of destruction is that they are nothing but machines of destruction, monuments of our evil and bloodthirsty souls. "If you don't want anyone to drop the bomb, don't build the bomb" is the way we should think, not "lets build the bomb before anyone else does" because maintaining the terror balance is the easiest way to put everything else out of balance. We waste far too much energy and money on increasingly advanced and ingenious ways to killing each other, instead of trying to live in harmony. And peace.
I prefer to let nature decide what happens to the mountain gorillas :rolleyes:
I'm afraid your have a terribly narrow-minded view of the world around you. Utopian pipe dreams of world peace are utterly impossible due to human nature, an unfortunate but real trait of our species.
I would prefer our military remains as up-to-date as possible to assure we are able to defend ourselves from the many people around the world that do not share your sentiments of living in harmony.
  • #36
Of course. Because even though the enemies you could beat hands down in the 70s are using the same old ex-soviet crap today and haven't advanced at all, you still need more advanced weaponry.
Military technology is a racket, plain and simple.
  • #37
You know, what started out here as a very interesting discussion of aerodynamics has become so political that I can't stand to read it any more.
ajSpades and Mech... your posts were quite in line with the way that things should be done here, and I learned a lot from both of you. Thank you. Unfortunately, I'm bailing out of this thread because of the aforementioned political biases. Catch you on the flip-side.
  • #38
Care to expand on that comment? Please enlighten us how that is. I am especially interested since I work on a few military R&D programs.
  • #39
Governments fund and purchase military equipment and projects that aren't necessary, for a variety of reasons. Cases in point: F-22; unnecessary; the current heavyweight fighter, the F-15, is already superior. Commanche and Crusader; canceled after huge expenditure because they were tactically worthless.
The major guilty party, of course, is the US. Is the US any better at winning wars now than it was 30 years ago, after huge expenditure in arms development? No, it is not. The main reason, as far as I can see, to heavily fund arms development is to keep those companies afloat. You'd want to do this for two reasons: Firstly, jobs and economic growth. Defence industries employ large numbers of highly skilled personnel and are major customers for many other industries. The high salaries of their skilled workers serve to invigorate the economy. Secondly, those companies are always around in case the government they contract for gets itself in dodge and really needs some rapid development of new technology. The idea that large military budgets spent on the latest high tech toys are necessary for the safety of a nation is a complete fallacy.
  • #40
I think I'll step in here if no one minds, given I know something about these things...
Incorrect, and under-informed. Do you know the RCS (that's Radar Cross Section) of an F-15 as compared to an F-22? Hardly superior. And moreover, since the F-15 does have a larger RCS, its chance of being detected and detroyed (and thus the loss of a life) can be statistically and physically be shown to be quite a bit higher than the F-22. These are facts, not underinformed opinions such as you have offered. Do you know that the F-22 is much more fuel efficient because of the Supercruise capability? That is superior to the F-15 and ANY other country's supersonic fighter.
Again, a trite response that is vacuous in its facts. For the time when the Comanche was first built (development, not production) the Comanche fit the tactical need at that time. In the intervening years the operational scenarios changed from battlefield encounters to what we are seeing now in Iraq, where a weapon system like the Comanche would not bring the benefits of its cost. The decision to NOT continue the Comanche to full-scale production was a prudent one. But that has absolutely no bearing on the technology developed during the DEM/VAL phase. I served for a time as the lead flight control systems engineer on the Comanche before it was terminated. There are many technologies that were developed on that program (similar to the F-15 vs. F-22 comparision above) which can and will be carried through on future vehicles and in retrofits. Again, you are passing judgement on these vehicles only from what you know, and I can tell you know fairly little technically, for you are not taking the technical factors into account.
By what metric are you coming to that conclusion? You can't just expect to throw out a naked assumption like that without supporting it with real numbers and hard facts. Are you aware of the combat casualty rate? Do you know how much it has gone down since the Vietnam era? That is a metric that would definitely prove your naked assumption incorrect.
These are two reasons, but not the primary reason. The primary reason is to always strive for better... not only because it assures you of having the best weapons, but because it leads to breakthroughs and technological benefits (ever hear of GPS and Internet? Both came from DoD) that can eventually benefit the whole society. But another reason is one you infer but never state outright... that is the fact that "one you lose technical dominance, it is downright difficult, if not impossible to ever get it back." Or as a admired president from our 60s said about our quest for the moon "'We do things not because they are easy, but because they are hard." (JFK) That, in and of itself, is worth the investment of society, even if no war is ever fought again (fat chance).
And again I must tell you that you are very one-sided in your analysis. That is not an insult, it is simply a fact. You have overlooked facts (such as the force multipler and life-saving benefits of stealth) to serve your agenda.
I'd suppose you think the F-35 is not needed because the F-18s and F-16s are "good enough", huh? And if you think so, I can give you some public facts about the JSF and what it means for force modernization and operational availability, to name just two metrics.
Let's talk hard facts, shall we? And we will see if you are even aware of some of the facts I deal with every day in my job.
Rainman
  • #41
For how long? The Sukhoi with thrust vectoring is flying, and quite well at that. How long until Russia starts stamping out copies? How long does it take to develop a fighter? That is not a reactionary endeavor. Once you realize that you are getting your butt kicked, or that the enemy is close to kicking your butt, it's too late. That is the attititude of new weapons design. To stay AHEAD of the curve. Also, technically superior does not tell the entire story. The F-22 is also expected to help save operational costs in the long run.
As a former Army aviator, I can tell you that your comment about the Comanche is not true. I had the opportunity to work on a part of the Comanche. The aircraft was flying and in working test flights when it was cancelled. There were a lot of reasons it wass cancelled, the top one being budgetary constraints, especially with the war in Iraq looming. The Crusader...well...not every military project is a success. However, I will bet you 10:1 that we will see something in the future that was possible due to work on that program.
Actually, it is. Have you seen the statistics on things like pinpoint munitions vs. conventional bombing? In Desert Shield we covered more ground, faster than any other military action. If anything has lagged in our war fighting is on the political end. Since we're asssigning guilt here, shouldn't you also be deriding all of the foreign governments that do the same thing? We hardly corner the market on government funded military research.
You will be hard pressed to find any company that relies completely on government contracts.
So the government putting money back into the pockets of its civilians through work is a bad thing? FDR did it and he is considered a saint.
I'll let you in on a little secret...our military has it's own, very large R&D development branches in each service. They are responsible for just as much development as us civilians. The main thing our government would need in a time of crisis would, most likely, be in the manufacturing sector's capabilities.
There are many leaps in technology that would have never happened or would have been greatly delayed had the prize of a government contract not been there. Great innovators like Sikorsky, Piascecki, Grumman and others owe their level success to their early military contracts. The governement is a great stimulus for innovaion that spills over to the civilian market sooner or later. Do you think you'd have a GPS in your car, or on every major ship and airplane today if it wasn't for the military?
