4 sides of the wire can produce a B-field
  • Thread starter Thread starter clovergogo
    B-field Wire
The discussion focuses on the magnetic field (B-field) generated by a wire and its interaction with forces. Participants question why the force is not directed downward despite the wire gaining weight and why the B-field direction is not outward from the page. The right-hand grip rule is referenced to explain the B-field produced by the wire's four sides. Calculations involving the formula i L x B are emphasized to determine the forces on different segments of the wire. The conversation concludes with a reminder to prioritize using the formula over worrying about the B-field direction.
clovergogo
clovergogo said:
http://upload.lsforum.net/users/public/m28175Untitledw43.jpg
Q 21 why the is not downward?? it gains weight!
The wire runs into/out of page. Calculate i L x B.
Q22 why the direction is not out of paper, by right hand grip rule, 4 sides of the wire can produce a B-field which is out of paper!?
i L x B again. This time, solve for B.
What forces are exerted on AB and CD? On BC?
Don't be concerned with the direction of the B fields generated by the wire. Use the formula!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
