How to find fundamental frequency
The discussion focuses on calculating the new fundamental frequency of a sculpture submerged in water, initially vibrating at 250 Hz when hung from a steel wire. The fundamental frequency is determined using the formula that incorporates tension and linear density. When the sculpture is submerged, the tension changes due to the buoyant force, which is calculated using Archimedes' principle. The ratio of the old and new tensions allows for the determination of the new frequency, indicating that the mass of the sculpture is irrelevant in this specific calculation. The final conclusion confirms that the 70 kg mass does not affect the frequency ratio.
ngcg
When a 70kg aluminum (density = 2.7 g/cm3) sculpture is hung from a steel wire, the fundamental frequency for transverse standing waves on the wire is 250.0 Hz. The sculpture (but not the wire) is then completely submerged in water. What is the new fundamental frequency?
f=ma
fundamental frequency = (1/2L)((Tensional force/linear density)^1/2)
250=(1/2L)((686N/u)^1/2))
(stuck there)
According to the Archimedes principle, the loss of weight is equal to the weight of the displaced liquid. In the problem the liquid is the water whose density is 1 g/cm^3.
Hence when the sculpture is immersed in water, the new tension is
T' = mg - mg*ρ(w)/ρ(Al)
The frequency is directly proportional to the square root of the tension. Hence
f/f' = sqrt(T/T')
250/f' = sqrt[1/(1 - 1/2.7)]
Now solve for f'.
so in this equation, the 70kg value does not matter?
by the way, thanks a lot! :)
Since we are taking the ratio of tensions, 70 kg does not matter.
thank you!
