How do you get a mouse trap car to go forward and then backward?
  • Thread starter Thread starter dxmichelle
    Car
To build a mouse-trap car that travels forward and backward, using two mousetraps is recommended, firing them sequentially. One trap can be modified to wind a rubber band, allowing for controlled movement in both directions. Suggestions include securing the trap firmly to the car and using a string mechanism to guide its motion. Additional resources and designs are available online for further guidance. This approach can help achieve the desired movement by Monday.
dxmichelle
I need to build a mouse-trap car that goes forward 3 meters and goes backwards 3 meters by Monday... is that even possible? Pls, help me with ideas... :bugeye:
By Monday? You'd better get cracking.
Best guess is use 2 mousetraps... Fire them off one at a time.
Why not have one wind a rubber band or something... you will have to adjust the tension but have it wind up then it should be able to get back..
here is some students who created a mousetrap car that went forward and backward with 2 traps like enigma said
http://www.andrew.cmu.edu/user/ejl/?M=D
Another two trap foward/backward design
http://www.andrew.cmu.edu/user/alauer/MecheDesign/mouse2.html
Tie the car to a string suspended from the ceiling?
Fix the mouse-trap FIRMLY to a little car. Fix the trap in a position such that when the wire thing comes to a stop, the momentum of anything attached to it will be in the direction the car will travel. Attach a weight to the end of that wire part. Put a spring on the front of the car. Put a firm support behind the car, so it can't jump backwards. Place a hard surface in front of the car, 3 meters away...
