Problem deal with accuracy of thermocouple
To ensure the accuracy of a thermocouple, it's recommended to test it in ice and boiling water to confirm it reads 0°C and 100°C, respectively. If the readings differ, such as a higher value for ice, adjustments may be necessary, like subtracting the error from future measurements. For applications requiring greater precision than ±1.1°C, consider using a thermistor or RTD instead. It's important to reference the thermocouple's specifications for accuracy limits and to document these in any presentations or charts. Additionally, ensure the cold junction reference is accurate, and use pure water for the ice test to avoid errors.
soonsoon88
How i am going to confirm or make sure the accurate of thermocouple before i use it for measurement in experiment?
Is it ok if ...
I put it in ice in order to get 0 Celsius and put in boiling water to get 100 Celsius?
In the idea case, i should get 0 and 100 Celsius from thermometer..
but what i should do if i got slightly different ?
I don't know how to present about the error if i use it for real experiment...i need help on it...please..
Just go and see what you get with ice and boiling water. That is a great idea to start with.
I did a try already..i got a slightly higher for ice. 1.1 Celsius..
If like this..
this mean i have to minus 1.1 Celsius for all value by using that device ?
If you need something more accurate than +/- 1.1 deg. C, use a thermistor or RTD. Don't use your TC's for that application. As far as results go, you should have some specs on that specific thermocouple that say what the accuracy of your measurements are. For example, +/- 1.5 deg over the range of 40 deg C - 375 deg C. Consider checking out OMEGA's website for typical errors for a thermocouple class.
If you need to present the temperature in a chart, simply plot the recorded values and add a foot note that shows the accuracy limitations. However, if you are taking the temperature measurements and using them to plot something as a function of temperature you probably need to adjust the accuracy accordingly. Google error propagation.
Unless you're at altitude.
That should be a mixture of ice and water to get 0, but make sure that you are using pure water, your other source of trouble is your cold junction reference how accurate is that?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
