amk_dbz said:
Sorry about the diagram...
Let me put my question in a different way using an analogy most commonly used.
Consider a car going from a good road to sandy terrain where the speed decreases (say due to slipping) at an oblique angle. (like light from rarer to denser material). Now only one wheel of car enter the sandy region first and slows down while the other wheel, which is still on road is traveling at higher speed. So the car bends inwards due to speed difference until both wheels enter the sandy region thus having same speed.
This analogy makes sense only when we consider the wheels to be joined together by say an axle which forces the car to bend.(If no connection was present then the wheels will continue their motion along respective straight lines with some lag in relative position changing distance between them)
{use the previous figure considering the two rays as the lines along the wheels of car and the situation shown in figure is without the "connection" between the wheels}
But what about light?? Do the photons have some connection between them?
Thanks...
No. Photons do not have some connection between them. The theory linking photons to light waves is a bit more complicated than that. However, the wave picture alone is sufficient to understand the basics of refraction.
A photon is a particle of light. Therefore, it isn’t always useful in describing the behavior of light waves. Concepts clearly defined in terms of waves are generally ambiguous with respect to particles. And vica versa.
The concepts of wave front and photon are mutually exclusive. There is an uncertainty relation between photon number and uncertainty in phase. It is a bit weaker that the other uncertainty relations, so there are strange exceptions. However, it is a good approximation under most conditions. Using this relation, the following can be shown. Under conditions where the light acts precisely like a wave, the concept of photon breaks down.
That is quantum mechanics for you. Quantum mechanics assumes wave-particle duality. However, going from a wave picture to particle picture involves probability and statistics.
If the wave front is defined precisely, then the phase of the wave is known precisely. If the phase is known precisely, than the photon number is completely uncertain. If the photon number is uncertain, then the concept of photon is not applicable.
http://en.wikipedia.org/wiki/Coherent_states
At , from Figure 5, simple geometry gives . From this we can see that there is a tradeoff between number uncertainty and phase uncertainty , which sometimes can be interpreted as the number-phase uncertainty relation. This is not a formal uncertainty relation: there is no uniquely defined phase operator in quantum mechanics [11] [12] [13] [14] [15] [16] [17] [18]
Another version of the uncertainty relation between photon number and phase is presented in equation 19 of the following link.
http://www.phys.tue.nl/ktn/Wim/MadMQND91.pdf
“We study a simple setup for non{estructive detection of photon number. We in particular
compare the device's inaccuracy and its phase disturbance to the uncertainty
principle. As the traditional uncertainty principle involves neither inaccuracy nor disturbance,
a new type of uncertainty relation is employed”
For historical completeness, the theory of Newton should be mentioned. Newton tried to explain many properties of light using the assumption that light was made of particles. These are now called Newtonian corpuscles. He explained refraction in terms of the pressure of the medium on the particles.
Newton totally ignored the wave nature of light. His theory didn’t precisely explain all the properties of light known at the time. Therefore, his theory was replaced by the wave theory of light. Einstein developed the theory of photons as a particle. However, Einstein applied his relativity theory to the photons.
Newtonian corpuscles are very different from photons. Photons travel at the speed of light. Therefore, relativity is needed to explain their properties. Photons do not satisfy Newton’s original, unmodified equations.
In any case, Newtonian corpuscles are also inconsistent with the wave nature of light.
