Conductors in large electric fields
When a conductor is placed in a strong electric field, its internal charges rearrange to create an opposing field, nullifying the field within the conductor. However, there is a limit to how strong this opposing field can be. If the external electric field exceeds this limit, the conductor may lose its conductive properties, potentially becoming an insulator. This can lead to phenomena such as field emission, where electrons are ejected from the surface, and possibly result in arcing. Ultimately, while the bulk of the material remains conductive, its behavior under extreme fields can change significantly.
gralla55
You place a conductor in an electric field. The charges inside the conductor will relocate, to form an opposing electric field which cancels the outside field, making the field inside the conductor zero.
However, surely there's a limit to how big an opposing field the charges in the conductor can create. My question is, what will happen if you place a conductor in an electric field larger than the conductors maximum opposing inside field?
Offhand I'd say you would ionize the conductor and rip it apart.
I would guess it not longer behaves as a conductor. Being a conductor means you have free and mobile charges. If your external field has pinned down all your charges then you now have an insulator.
Right, you get field emission, which is the emission of electrons from the conducting surface. Eventually you could get an arc (lightning bolt).
No, the bulk metal is still a conductor.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
