Energy of an electromagnetic wave
The energy of an electromagnetic wave is calculated using the equation E=hf, where E is energy, h is a constant, and f is frequency, indicating that energy is primarily related to frequency. Amplitude does affect energy, but it does so by influencing the number of photons produced; higher amplitude results in more photons, which contributes to total energy. For coherent light, doubling the amplitude increases energy by four times due to the square relationship with field strength, while for incoherent light, doubling the amplitude only doubles the energy. This distinction highlights the different behaviors of coherent and incoherent light regarding energy and amplitude. Understanding these principles clarifies the relationship between amplitude, frequency, and energy in electromagnetic waves.
anorred
So I've seen this equation used to calculate the energy associated with an electromagnetic wave:
E=hf
E is energy, h is a constant, and f is frequency. Therefore, the energy is related to frequency alone. However, why wouldn't the amplitude of that wave have an effect on the energy? I don't get it. If you have an extremely intense radio wave that requires much more energy to generate than waves such as your cell phone, why doesn't this equation show the effect of amplitude?
Because when you take amplitude into account is like adding E=hf. E is the energy in one "em" wave. So with higher amplitude you are having more photons or "em" wave quanta which adds up.
Do you know exactly how they add up?
They add linearly. Ten times as many photons is ten times as much energy. Is that what you were asking?
Yes, that was what I was asking.. in a way. If you had an amplitude that's 10x the magnitude of one photon.. would you add ten photons? I'm a noob.
The energy in an electromagnetic field is proportional to the square of the field strength (amplitude). So for coherent light, doubling the amplitude takes four times the energy and four times the number of photons, all else being equal. The rules for incoherent light are different, doubling the mean amplitude then takes just double the energy, and we use time-average values.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
