Cable segment and repeater spacing.
  • Thread starter Thread starter Physicist3
    Cable
The maximum length for UTP and STP cable segments, specifically for CAT-5 and similar systems, is 100 meters according to ANSI/TIA/EIA standards. A repeater or switch is required for longer runs beyond this limit. The specifications for 10BASE-T networking also support a 100-meter length between active devices, allowing for 90 meters of fixed cabling and two 5-meter patch leads. Other network types may allow for longer distances but typically at lower data rates. Adhering to these standards ensures optimal network performance and reliability.
Physicist3
Hi, I've read that the max length of UTP and STP cable segments is 100m? Does this mean that a repeater is required after every signle cable segment?
You didn't say it, but you must be referring to CAT-5 or similar systems?
http://en.wikipedia.org/wiki/Category_5_cable#Maximum_cable_segment_length
wikipedia said:
Maximum cable segment length
According to the ANSI/TIA/EIA standard for category 5e copper cable (TIA/EIA 568-5-A[5]), the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater or switch is necessary.[6][7] The specifications for 10BASE-T networking specify a 100 metre length between active devices.[8] This allows for 90 metres of fixed cabling, two connectors and two patch leads of 5 metres, one at each end.
For other network types, you can go much farther, but at lower data rates.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
20K
10K
