How to Purify Methane from Biomass for Clean Burning?
  • Thread starter Thread starter iwant2beoz
    Methane
Purifying methane from biomass involves dealing with byproducts like CO2, water vapor, and potentially hydrogen sulfide, which can affect combustion quality and engine components. While the gas can be burned as is, the presence of impurities may lower heating value and create dirty exhaust. Concerns about hydrogen sulfide's toxicity and its potential to damage engine parts are significant, prompting interest in purification methods. Suggested purification techniques include bubbling the gas through alkaline solutions and using silica bed dryers, though the necessity of extensive cleaning is debated. Ultimately, the goal is to ensure the methane burns cleanly and does not damage the turbine engine over time.
iwant2beoz
Hello does anyone know an easy way to purify methane made from biomass? I am not sure what gases I am producing but i know i have methane, CO2 and water vapor, and maybe hydrogen sulfured judging from the smell. I want to get a product clean enough to burn in place of nature gas. Thanks for the help
Chemistry news on Phys.org
You can probably burn your gas as is, even though it has a lot of other stuff with it.
The heating value would be lower, because of the inert components and the exhaust would be a bit dirty, from the burning hydrogen sulfide.
Just check to make sure your methane percentage is high enough to avoid the chance of explosion.
I know that it will burn, i tested that. But i worry that the water and hydrogen sulfured could damage the rotter blades in the engine I am working on.
Hydrogen sulfide stinks so bad the human nose picks it up at the part per million level, which is good, because it is actually more poisonous than hydrogen cyanide.
You can spend the effort to clean up your gas, bubble it through alkaline solution to strip the CO2 and maybe copper nitrate for the H2S and then a silica bed drier, but why bother? Unless you plan to run your engine for a long time, nothing biologically sourced will do much damage. We're not looking at 10% H2S levels here, as could be the case with raw well gas
My goal is to build a turbine engine that runs on methane, but i worry that over time the blades will get pitted and brake and i don't want to ruin months of work and wast all the money I am putting into this prototype. And i also want it to burn cleanly. So i will try cleaning the gas before i use it. Thank you:)
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
