Capacitance & Inductance in Diff. Dielectric Mediums
Calculating the capacitance of a twisted wire pair in different dielectric mediums can be complex, especially in 3D. The user initially planned to use FastFieldSolver for modeling but encountered software issues. An alternative approach discussed involves taking 2D snapshots of the wire's configuration and averaging the capacitance values. Recommendations for resources include a website with cable design equations and General Cable's electronics catalog, which contain relevant formulas. The visibility of these resources on search engines may be limited due to their content being in image format rather than text.
roTTer
Hello!
How do I calculate the capacitance of a twisted wire pair in 3D? The pair of wire would have two different dielectric(air and insulation) mediums and hence I am not able to figure out how to calculate it by hand.
My plan was to create a 3D Model, mesh it and put it up in FastFieldSolver. But that software is not working.
Another one was to just take 2D snapshots of the wire in different positions as it twists around each other, cascade the capacitance and get the average of those values.
But since that software is not working, can you please link me to a free/evaluation software that would allow me to do this?
Also do you have a way in mind which would allow me to do it by hand or a script?
Thank you for your time!
This is great! I was just looking at the wrong areas!
These sites really didn't show up on the first few pages of google because of the formulas not being indexed maybe due to the fact that the content are in a image format and not text!
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
