Cooling a 10x20 Shed: Tips & Tricks
  • Thread starter Thread starter icor1031
    Cooling
To effectively cool a 10x20 shed, installing an air conditioner is essential, especially if the interior temperature needs to be lower than the outside due to direct sun exposure. While R11 insulation on the walls helps slow heat transfer, adding insulation to the ceiling is recommended to enhance cooling efficiency. Closing off the open space beneath the chipboard floor can further reduce heat influx. Consider using a reflective roof to minimize heat absorption and potentially upgrading to a more powerful air conditioning unit if necessary. Proper insulation and ventilation strategies are crucial for maintaining a comfortable temperature in the shed.
icor1031
I have a 10x20 shed. It has a chipboard floor, and below that is about 8" of open space, which wind will blow through. If needed, I can close it off - but I cannot insulate it.
My main concern is not with heating the room, although that would be a nice benefit. By far, my concern is with cooling it.
I can add an A/C, but I am using R11 insulation on the walls. I can put R11 on the ceiling also, but again - I cannot insulate the floor.
With all of that considered, and considering that heat rises, and R11 is such a low value - would I be better off to *not* use an A/C, and to leave the ceiling without insulation?
And any other tips or tricks are appreciated.
Thanks!
Thanks!
If the outside is warmer than you want it to be inside, you will need an air conditioner. This is the case whether you have insulation or not. The insulation will just slow down the rate at which heat flows into the building. When the inside gets as warm as the outside the insulation doesn't matter if you have no A/C. The inside can get warmer than the outside if the building is exposed to direct sun.
The insulation will affect how much work the AC has to do to keep the room cool. So it would be a good idea to insulate as much as possible and to close off the air circulation below the floor.
AM
The building is exposed to direct sun, and that is my concern: that the A/C cannot keep up with the heat created by the direct sun.
I believe the A/C is 12,000 BTU.
What do you suggest, for this?
AM
Definitely insulate the ceiling. You might also put in an attic fan if there is an attic. This will prevent the buildup of heat under the roof. Having a reflective (white or silver) roof will also help a lot. Other than that, get a more powerful A/C.
AM
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
