Transformer Current Drops with Load
As load impedance on a transformer secondary increases, the current drawn decreases due to Ohm's Law, which maintains a constant voltage. The power in the primary equals the power in the secondary, meaning that as secondary current decreases, primary current also reduces. The discussion highlights a potential language confusion regarding the terms "increasing the load" versus "increasing the load impedance." Clarifying these terms is essential for accurate understanding of transformer behavior. Overall, the relationship between load impedance and current draw is crucial for transformer operation.
Physicist3
Hi,
I have observed that as the load applied to a transformer secondary is increased (i.e. Increased Impedance), the current drawn by the transformer seems to decrease. Is this purely due to the fact that because the voltage remains fairly constant and the impedance is increased, the current must be reduced to allow ohms law to be maintained??
Thanks
Power in the primary will be the same as power in the secondary. Wp = Ws
Therefore Vp * Ip = Vs * Is
Increasing the load impedance will reduce the secondary current according to Ohms Law.
That in turn will reduce the primary current.
“Increase the load”? Or “increase the load impedance” which would reduce the load?
A language problem here: The term "Increasing the load" involves increasing the Current, which implies Decreasing the Resistance (Impedance) of the Load.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
