How Do Rotor and Stator Pole Numbers Affect BLDC Motor Efficiency?
The discussion centers on the relationship between rotor and stator pole numbers in Brushless DC (BLDC) motors and their impact on efficiency. It is noted that while rotor and stator poles do not need to be equal, having more rotor poles requires faster stator winding firing to maintain the correct angle between magnetic field vectors for optimal torque. The inquiry also raises the question of how multiple stator poles, such as 12 or 18, affect the alignment of magnetic fields with the rotor. A participant suggests that any configuration can work as long as there is proper alignment during stator firing. The conversation highlights the complexity of pole interactions and their implications for motor performance.
jainabhs
hi,
There is one thing that I do not understand and nor do I find any direct explanations for it.
Is there any relationship between no of rotor poles and no of stator poles in BLDC motor (or PM Synchronous Motor)? I have read somewhere there doesn't have to be. I can imagine if no of poles are same then each rotor pole would interact with stator pole. But it is difficult for me to imagine if the numbers are unequal.
Can somebody explain or point to any resource...
Thanks in advance.
aj
Thanks meBigGuy for pointing to this page.
Although I have been to this page before, some how when I read it this time, I got slightly better idea what is going on. So it looks like if you have more rotor poles, you have to change the stator winding firing more rapidly than for less no of poles (feedback from hall/bEmf) so that rotor and stator magnetic field vectors have certain angle (I think is 90 degree) maintained between them, which produces the required torque.
But half part of my question is still open, let me rephrase, if we have six stator poles (2 poles per phase for 3phase motor) then we will have one stator magnetic field vector. What is we have more stator poles like 12, 18 will we have more than one mag field vectors to align with rotor's field.
Let me know what you think or have some other resource on this.
I'm not very strong in this area.
My assumption would be that you can have any relationship as long as there is proper alignment between the stator and rotor when the stator(s) is/are fired. (I'm thinking like a many legged Y or multiple Y's). I have not researched what is available.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
