Acceleration to Velocity by area integration
The discussion focuses on integrating acceleration data from MEMS accelerometers to derive velocity. A referenced Freescale application note is critiqued for neglecting the sampling time in its area calculation formula. The original poster questions the accuracy of the formula provided, suggesting it should incorporate time more explicitly. There is confusion regarding the placement of parentheses in the formula, leading to concerns about its validity. The conversation emphasizes the importance of correctly accounting for time in the integration process to achieve accurate velocity calculations.
likephysics
I know this has been asked many times.
I am integrating acceleration data from MEMS accelerometer to get velocity.
I found an app note by freescale - http://cache.freescale.com/files/sensors/doc/app_note/AN3397.pdf
It ignores the sampling time to calculate the area.
The formula should be sample: Vx= V(x-1)+[N-(N-1) * T]. Right?
But the app note it is -
Vx = V(x-1)+N+[((N-(N-1))/2]
V(x-1) is the previous integration result.
... you still have to multiply by time somewhere.
N+[((N-(N-1))/2]
... nonsense: did you misplace a parenthesis?
N+[((N-(N-1))/2]=N+1/2
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
