What Are the Work Relations for Different Processes in an Ideal Gas?
The discussion focuses on the work relations for an ideal gas during various thermodynamic processes, including isometric, isothermal, polytropic, and isobaric. The polytropic process is highlighted as the most general, with the equation PV^n = constant applicable for work calculations. The work done during compression or expansion is expressed as W = (m R (T2 - T1) / (1-n) or W = (P2 V2 - P1 V1) / (1-n), depending on the process. Specific values for the polytropic exponent n are provided for isentropic (ratio of specific heats), isobaric (n=0), and isothermal (n=1) processes. The conversation concludes with a suggestion for further resources on the topic.
blinder
I was wondering if anyone knows where i can find the work relations for an ideal gas including isometric, isothermal, polytropic, isobaric, etc.
Hi blinder. I'm assuming you're looking for the equations to calculate the work done on an ideal gas when undergoing the various processes you've listed. A polytropic process is the most general, so we can start with that. Also, the equations should work just as well for compression or expansion (work in or out of the gas).
As you must already know PV^n = constant is a polytropic process. If you compress a gas, the work done is the integral of PdV. If we integrate that for a polytropic process you end up with:
W = (m R (T2 - T1) / (1-n) = (P2 V2 - P1 V1) / (1-n)
where m = mass
R = Gas Constant
T = temperature
n = polytropic exponent
P = absolute pressure
V = total volume
(for any value of n except 1)
For an isentropic compression, n = the ratio of specific heats of the gas (ex: 1.667 for a monotomic gas, 1.4 for a diatomic gas, etc...)
For an isobaric process, n = 0
For an isothermal process, n = 1 so you need to do the integration using n=1 which comes out to:
W = mRT ln (V2/V1) = mRT ln (P1/P2)
Hope that helps.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
