A Basic Function Problem with a Limit
  • Thread starter Thread starter DMOC
    Function Limit
DMOC
For all real numbers x and y, let f be a function such that f(x+y)=f(x)+f(y)+2xy and such that the limit as h approaches zero is f(h)/h=7. \stackrel{Lim}{h\rightarrow0}\frac{f(h)}{h} = 7
a) Find f(0) and justify your answer.
b) Use the definition of the derivative to find f ' (x).
c) Find f(x).
NO CALCULATOR USE ALLOWED!
Limit as h->0 is (f(x+h)-f(x))/h
To solve part a, I looked at the original equation. To find f(0), I just put in 0 for x and 0 for y.
Let x=y=0.
And thus, I got f(0)=0, so now part a should be cleared. Right?
Then I get to part b and I'm a little stuck. Find f ' (x) ? Should I be using the equation I put in the relevant equations section to help me out with this?
The definition of the derivative is the equation that you gave, so yes.
OKay, so here goes my shot at part b (do you think part a is right?):
f ' (x) is ...
(f(x+7) - f(x)) / 7
Hm ... I'm getting a little lost here. I just substituted h for 7.
Also, is there a way to post these fractions using the latex reference?
you want to start with:
\stackrel{Lim}{h\rightarrow0}\frac{f(x + h) - f(x)}{h}
What can you say about f(x + h)?
to do the fractions, just use \frac{}{} where the numerator goes in the first bracket pair and the denominator goes in the second.
Thanks for letting me know about the fractions part.
For f(x+h), I was thinking that would just be equal to f(x) since h is approaching zero. However ...
Which doesn't make sense anyway since that would be undefined as h approaches zero. Hm ...
You have the formula for f(x + [strike]y[/strike]h) in your original post ;)
Also, \stackrel{Lim}{h\rightarrow0}\frac{f(h)}{h} = 7 according to your original post. You edited it but left the old version. Which one is it?
Sorry, the limit as h goes to zero is definitely SEVEN. :smile:
So how about this. I was thinking that since I could do this ...
f(x+y) = f(x) + f(y) + 2xy
f(x+y) - f(x) = f(y) + 2xy
Then couldn't I say that since h is approaching zero, then it figures that:
x=y=0=h as well. I can then substitute the h's in for x or y?
Am I on the right track here?
well f(x+h) - f(x) = f(h) + 2xh is right but that's inside a limit and over h as h goes to zero.
now, as I'm sure you know, the sum of limits is the limit of sums. So do it like that. There is no y in this equation and you can't set x to a value because you're taking the limit for all x so it needs to remain a variable.
I'm not sure what to do what you said, because we never discussed limits in my class yet.
Ok. I don't think there's a way to do this without limits as they're in the problem as stated so the rule you want is:
\lim_{h\to a}(f(h) + g(h)) = \lim_{h\to a} f(h) + \lim_{h\to a} g(a)
See if that helps.
See if that helps.
I think this problem requires knowledge of limits, although I never learned that last year (I think my teacher expected us to know from last year).
So for part b:
f ' (x) = \lim_{h\to 0} (f(x+h)/h) + \lim_{h\to 0} f(x)
Hopefully this is on the right track.
That's the idea but do you remember how to expand f(x + h)?
Just keep it in one limit until you have expanded f(x + h) and the f(x) cancels out like it did before. And remember that when a sum is on top of a fraction, the denominator goes with both sides of the sum if you split it up!
\frac{a + b}{c} = \frac{a}{c} + \frac{b}{c}
Revised version.
f ' (x) = \lim_{h\to 0} ((f(x+h)/h) + f(x/h))
And, no I do not know how to expand f(x + h). I know this is easy once I understand the concept but I'm really new to it, sorry.
That's ok. Look at your original post and post #8 and #9 in this thread. You've already done it
Really?
So do I substitute f(h) + 2xh for f(x+h) - f(x) now?
I'm still a bit confused, sorry.
No problem.
Try it and see what happens. Post your results!
\stackrel{Lim}{h\rightarrow0}\frac{f(y) + 2xy}{h}
Do I put an equal sign after or before the limit part?
Ok, where is the y coming from?
The y comes from ( f(y) + 2xy ) being equal to ( f(x+h) - f(x) ).
Ok, but you're taking the limit with respect to h so it starts of as f(x + h) - f(x). Why are you switching to y?
Not sure, really, since a classmate of mine told me that I might have to do something like that. Yeah, clueless.
Should I set h equal to something to help me find the derivative of f ' (x) ?
No, you can't set anything equal to anything.
you have \lim_{f \to 0}\frac{f(h) + 2xh}{h} given the rule I gave you earlier for the sum of a limit, can you figure it out from there? you already know what \lim_{f \to 0}\frac{f(h)}{h} is. How does the value of 2x change when h changes? (assuming that x is fixed)
\lim_{h \to 0}\frac{f(h)}{h} + \lim_{h \to 0}\frac{2xh}{h}
The second part would just cancel out since it's a straight up 2xh/h problem wher ethe h's cancel. 2x remains.
f ' (x) = 7 + 2x
Just wondering, but how did you replace f(x) with 2xh?
I didn't. We replaced it with 7 because that's what the problem specifies! The h's do cancel when taking limits. So now how do you get f?
Where does the problem specify that f(x) = 7?
Okay, so f ' (x) = 7 + 2x seems to be the answer for part b.
Now for f(x), that equals:
f(x + y) - f(y) - 2xy
Am I supposed to put in 0 for y?
Sorry, i was being sloppy. I shouldn't do that. \lim_{h \to 0}\frac{f(h)}{h} = 7 is specified in the problem.
Do you know how to integrate?
We're not going to be setting anything to anything for the rest of the problem so quit thinking about it! ;) It was a good trick for part (a) but we don't need it anymore.
I have no idea what integrating is ... our teacher expected us to know stuff from last year, but I took a different class from the rest of my classmates. :(
So any clues on how to find f(x)?
Well, do you know how to take derivatives?
  • #31
Yes.
  • #32
Cool! Think of a function that has 7 + 2x as its derivative.
(f + g)' = f' + g'
so you can just do it for 7 and 2x and then add the results.
  • #33
7x and x^2
Well, x^{2} + 7x
  • #34
you got it.
  • #35
You might want to talk to your professor or a classmate and find out what they expect you to know so that you can read up on it.
  • #36
f ' (x) = 7 + 2x
Thanks for helping man ... are you a teacher?
But there's just one more thing I'm confused about after this problem.
\lim_{h \to 0}\frac{f(x+h) - f(x)}{h} is the formula for derivatives as h approaches zero.
However, we eventually ended up with what you see in the quotes.
I had to substitute h in for y but you said that I wasn't supposed to do it, but that's how we got there ... thanks again for your help.
  • #37
Okay, we started with the definition of a derivative. used the fact that f(x + y) = f(x) + f(y) + 2xy to rewrite the top part of the derivative which is f(x + h) - f(x) as f(x) + f(h) + 2xh - f(x) = f(h) + 2xh.
You should be able to take it from there. Read through the thread again if you need to.
  • #38
Got it.
I was wondering why you seemed to have a weird "y" before I realized it was actually a strikethrough. ;)
  • #39
Oh my bad man! And here I thought I was being slick! I'll keep that in mind in the future. Sorry for any confusion it may have caused.
  • #40
No worries, got it now. :)
