A basic question on Electromagnetic Induction
The discussion revolves around the effects of a falling bar magnet on a circular loop, specifically questioning whether the magnet's acceleration is less than, greater than, or equal to gravitational acceleration (g). The book's explanation cites Lenz's Law, indicating that the loop generates a north polarity facing the magnet, causing a repulsive force that slows the magnet's descent. Participants express confusion about the underlying principles of magnetic repulsion and the creation of magnetic poles in bar magnets. Clarifications are provided regarding the nature of magnetic fields and forces, with references to the behavior of current-carrying wires and the role of electron motion in generating magnetism. The conversation concludes with a better understanding of magnetic pole creation and the application of the cross product rule to analyze the forces involved.
Abhishekdas
There is a circular loop in the horizontal plane and a bar magnet (with its north pole downwards) Is falling down along the axis of the loop...
Now is the acceleration of the bar magnet less than,greater than or equal to g?
The explanation in the book is given as: The side of the loop facing the bar magnet is getting a North Polarity (this is because the direction ofcurrent is antclockwise from top by Lenz's Law). Now like poles repel and hence the bar magnet's acceleration is less than g...
Firstly I am not totally convinced by this concept . I mean i know like poles repel from a young age but at this stage i would like to know how exactly it happens(like in electrostatics Coulumb's Law gives the dir of forces which proves that like charges repel) and it would be great is someone explains me that.
Secondly i was trying to figure this out with the concept of force due to a magnetic field...But i can't do so because in a bar magnet where is tha charge? and what is the velocity? So basically I am clueless...So guys help me out...
I've attached a diagram for the sum if you need it...
Thank you...
Okay, how about the fact that parallel wires attract each other when their currents are in the same direction, and repel if the currents are in the opposite direction? If you can accept that as an observed, experimental fact, then I offer the following explanation:
Imagine two equal loops, one above the other, and their planes are parallel to each other. Also, imagine that each has a current, but the currents run in opposite directions for the two loops. Since the currents are in opposite directions, the loops will repel each other, just as two parallel wires repel when their currents are in opposite directions.
But, the opposite currents means that one loop has its N pole upward, and the other has its N pole downward. So the loops have like poles pointing at each other. And we already know that the loops repel, so ... end of story.
The charge is in the protons and electrons of the atoms. We don't know "the velocity", but it is primarily the motion of the electrons that gives rise to the magnetic field.
and you can easily prove how parallel currents in same direction attract using right hand ruld or cross product rule
Hi Redbelly98...
The explanation which you gave does convince me about two loops but i exactly don't know how poles are created in bar magnets...Is it the same kind of thing...are there rectangular loops or something in bar magnets too? I google about "how poles are created in bar magnets" but didnt get any convincing answer as such...So maybe you ca help me out there...
And hi cupid.callin...
I know how to prove that parallel current carrying wires attract or repel depending on the direction of current...but here in case of a bar magnet as i mentioned above i don't know how poles are created in magnets...So i don't know how to go about finding the force due to the magnetic field...
Anyway thank you both...expecting a reply soon...
This will help you
Hey cupid.callin thanks a lot...
this was of great help and this kind of a text was exctly what i was looking for...The pole creations in a bar magnet...Now i applied cross product rule and got my answer about how they repel...really thank you so much...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
