Mephisto said:
ok well I'm totally confused then. The first case was that train goes along line x=0 upwards, and the bird flies at x=-1 or something right beside it, but it also has a very slight component in the x direction, so that it eventually gets into the train.
Lemme try answering this question again.
Let ground be our frame of reference.
Let a car of a train start at coordinates (0,-a) where a is a large number and the train is moving at a velocity, v along the the line x=0 (the y-axis) in the positive direction.
At the start, let the bird be at coordinates (1,-a).
Now I am slightly confused here because, if the bird is moving at the same
velocity as the train, the bird and the train will never meet. So, I'm assuming that the
y-component of the velocity of the bird is the same as the train.
So let the y-component of the velocity of the bird equals the train and the x-component of the velocity of the bird is in the negative direction and has a low magnitude.
Let the bird enters the car of the train through one of the side windows at coordinates (0,0).
The line traced by the moving car of the train is x=0 for y > -a if the train continues move indefinitely.
The line traced by the flying bird is
y = -ax \ \mbox{for} \ 0 > x > 1
Now, if I'm sitting inside the train and looking out the window, I will see an almost stationary bird that is moving closer and closer to the window, wouldn't I?
Switching back to the original frame of reference (the ground),
Once the bird enters the train, the y-component of the velocity of the bird increases (the bird accelerates) if the bird retains the same flapping as it does outside the train. Since the air inside the train is moving wrt to the ground, it should cause the bird to accelerate compared to the bird flying in still air, outside the train.
The x-component of the velocity of the bird remains the same.
The bird should exit the train through the window a few windows in front of the window opposite the window it entered. (exits through the window closer to the front of the train than the window that it used to enter the train)
So, the line decribed by the bird would be
y = -ax \ \mbox{for} \ 0 < x < 1
and
y = -ax + b \ \mbox{for} \ x < 0
Where b is caused by the acceleration of the bird in the train and
assuming that the width of the train is infinitesimally small.
Anyway, in reality, the width of the train wouldn't be infinitesimally small, but, because of the acceleration of the bird inside the train, the line described by the bird while it's flying inside the train in our frame of reference should have a steeper gradient compared to the line it described when it's flying outside the train. That is what I think of this question, for now...
