Python Efficient Factorial Calculation in Python: Recursive vs. Iterative Methods
  • Thread starter Thread starter Whovian
    Bit Python
The discussion centers on a Python implementation of functions to calculate combinations using factorials. The initial code attempts to compute binomial coefficients but encounters a recursion error due to the factorial function not handling negative inputs, which can lead to infinite recursion. It is emphasized that factorials are undefined for negative numbers, suggesting the need for input validation and exception handling to enhance the robustness of the code. Additionally, the inefficiency of using a recursive approach for factorial calculations in Python is noted, with an alternative iterative method provided. Performance comparisons using the `timeit` module reveal that the iterative method is significantly faster than the recursive one. The conversation also touches on programming practices, debating the necessity of defensive programming versus practical application scenarios, such as web apps where precomputed values might be more efficient.
Whovian
I tried the following code:
Code:
def factorial(n):
    if (n == 0):
        return 1
    else:
        return n*factorial(n-1)
def ncr(n,r):
    return ((factorial(n))/(factorial(r)*factorial(n-r)))
number = 0
for n in range(100):
    for r in range(100):
        print ncr(n,r)
Basically, for all n and r from 1 to 100, it's supposed to print ##\binom{n}{r}##
Unfortunately, running from the command line, I get:
Code:
Traceback (most recent call last):
  File "Pythontest.py", line 14, in <module>
    print ncr(n,r)
  File "Pythontest.py", line 8, in ncr
  File "Pythontest.py", line 5, in factorial
Technology news on Phys.org
you have to have 0 \le r \le n. your definition of factorial goes into an infinite callback if n &lt; 0.
Also, for general purposes...factorial is not defined for negative numbers, so, you should enhance your 'def factorial' and guard (validate) against negative numbers and possibly raise an exception, etc...you know, for when you use this def in a more complex program.
Oh. Oops.
Also sound advice.
May I ask why you are doing it recursively? It's not particularly efficient in Python when done that way.
Code:
def rfac (x):
    return x * rfac (x-1) if x > 0 else 1
def ifac (x):
    f = 1
    for i in range (1, x+1):
        f *= i
    return f
from timeit import Timer
print (Timer ("rfac(20)", "from __main__ import rfac")).timeit()
print (Timer ("ifac(20)", "from __main__ import ifac")).timeit()
$ python fac.py
10.4178638458
5.76771497726
There are much faster ways to compute it, if you search the web.
Edit: I am not sure I would check or throw for negative input. There's defensive programming, and there's paranoia. It should not happen in practice. I admit this is personal style. I understand there cases where it might (web app), but seriously ... use a precomputed lookup table of N! if it's a web app.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
