A charge accelerating between two plates
An alpha particle with a charge of 3.2 x 10-19 C accelerates between two oppositely charged plates in a uniform electric field of 39,000 N/C over a distance of 4.50 x 10-3 m. Despite the uniformity of the electric field, the potential energy of the alpha particle does change as it moves from the positive to the negative plate. The particle gains kinetic energy due to the work done by the electric field, which is a conservative field. This process illustrates the relationship between work and electrostatic potential energy. Understanding these concepts is crucial for analyzing particle dynamics in electric fields.
Googl
Hi all,
Suppose an alpha particle of 3.2 x 10-19 C accelerates from rest between two oppositely charged plates starting from the positive plate. The electric field between the plates is uniform equal to 39000N/C. The distance between the plates is 4.50 x 10-3m
Does the alpha particle potential energy change? I assume since the field is uniform then the PE will not change.
There is a change. When the particle travels from the positive to the negative plate, it accelerates and acquires some kinetic energy (and radiates some too). The necessary work has been done by the electric field and, since it is a conservative field, there is an associated change in electrostatic potential energy
To see the relation between work and voltage, check out http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elewor.html"
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
