A couple of not so simple problems from old contests
  • Thread starter Thread starter myro111
    Couple
The discussion revolves around solving several challenging math problems from past contests, including polynomial equations and their properties. The first problem involves proving that the product of two roots of a quartic polynomial is a root of a specific sextic polynomial, with a suggested approach using polynomial division and Vieta's formulas. The second problem requires proving that all roots of a quintic polynomial are real under a certain condition involving coefficients. Other problems include determining the number of rational solutions for a polynomial and analyzing the coefficients of a quotient from polynomial division. Participants express uncertainty about how to tackle these problems, highlighting the complexity and depth of the mathematical concepts involved.
myro111
I found some problems from old contests in my book and I need some help solving them since I could not find the solutions online.
Some USA contest problems:
1.(1977.)Let a and b be 2 solutions of x^4+x^3-1=0 .Prove that a*b is the solution of x^6+x^4+x^3-x^2-1=0
2.(1983.).Prove that all the solutions of x^5+ax^4+bx^3+cx^2+dx+e=0 are real if 2a^2<5b
German contest
3.(1977.)How many pairs of numbers p,and q from N which are smaller than 100 and for which x^5+px+q=0 has a rational solution exist ?
Moscow olympiad
4.(1951.) Dividing the polynomial x^1^9^5^1-1 with P(x)=x^4+x^3+2*x^2+x+1 we get a quotient and remainder.What is the coefficient next to x^1^4 in the quotient?
5.(1955.)If p/q is the root of the polynomial f(x)=a[0]*x^n+a[1]*x^n^-^1+...+a[n] and p and q don't have common divisors.If f(x) has integer coefficients then prove that p-k*q is a divisor of f(k) for every integer k.
Thank you very much!
What have you tried so far? Do you have ideas how to tackle them?
1. Divide the second polynomial with x-ab and I get as a remainder (ab)^6+(ab)^4+(ab)^3-(ab)^2-1 The remainder is the second polynomial but instead of x it is ab.I got this idea because if we have a polynomial P(x),a is the root only and only if P(x) is divisible by x-a,and that fact is well known.The other idea was Vietes formulas but couldn't get anything.
2.No idea.
3.No idea
4.No idea.
5.No idea.
I'm kidding myself that I have anything close to the knowledge required to solve these, but...
Write x^6 + x^4 + x^3 - x^2 - 1 = 0 as x^4 + x^3 - 1 = x^2 (1 - x^4), substitute x = a, that should help you to get a range of values for ab.
Dont worry I solved it another way.But thanks for the try.I used Vietes formulas
