A disk with a Spring around it
  • Thread starter Thread starter lebprince
    Disk Spring
The discussion revolves around a physics problem involving a disk with a string wrapped around it, where a constant force is applied to the string. Participants calculate the moment of inertia for both the disk and attached masses, arriving at a total moment of inertia of 0.229925 kg·m². They emphasize the importance of considering both linear and angular accelerations, as well as torque, to solve for the speed and angular speed of the apparatus. Key equations discussed include F = ma for linear acceleration and torque calculations using the radius and net force. The conversation highlights the need to clarify the correct radius for torque calculations, which is the perpendicular distance from the force's action point to the center of rotation.
lebprince
A string is wrapped around a uniform disk of mass M = 2.5 kg and radius R = 0.05 m. (Recall that the moment of inertia of a uniform disk is (1/2)MR2.) Attached to the disk are four low-mass rods of radius b = 0.09 m, each with a small mass m = 0.7 kg at the end. The device is initially at rest on a nearly frictionless surface. Then you pull the string with a constant force F = 27 N. At the instant when the center of the disk has moved a distance d = 0.038 m, a length w = 0.020 m of string has unwound off the disk.
(a) At this instant, what is the speed of the center of the apparatus?
v = m/s
(b) At this instant, what is the angular speed of the apparatus?
(c) You keep pulling with constant force 27 N for an additional 0.035 s. Now what is the angular speed of the apparatus?
I have no idea how to approach the problem. any help please
Well, a good place to start would be to determine the moment of inertia of the object.
ok so the moment of inertia of the object is 1/2Mr^2 so = 1/2*2.5*(0.05)^2 = 0.003125
That we be the moment of inertia of the disk. What about the the small masses?
ok since we have 4 masses ; m1r^2 + m2r^2 + m3r^2 + m4r^2
so 0.2268
so 0.2268
Correct. So the total moment of inertia is the sum of this and the moment of inertia of the disc.
What do you suppose the next step will be?
umm am assuming i have to find the angular speed cause it would one one way to find V, but i know the Lrot = IW but i don't have Lrot
Consider the force and resultant accelerations of the body.
so i can use F = mxa?
Yes, but you also need to consider the torque on the body.
ok..so i can find the torque on the body using r x Fnet, now is r the distance the center of the disk has moved? so 0.038 x 27 = 1.026? and F = mxa so a = f/m = 27/2.5 = 10.8
No, r is the [perpendicular] distance from the point of action of the force causing the torque and the centre of rotation.
ok so i would use 0.05 x 27 = 1.35 and F = mxa so a = f/m = 27/2.5 = 10.8
