How Do I Solve Polynomial Division and Trigonometric Identities?
  • Thread starter Thread starter Jimmy84
    Division
To solve the polynomial division of (x^2 - 8x + 15) by (3 - x), it is suggested to reorder the polynomials in descending powers and consider synthetic division. The correct approach involves recognizing that dividing by (3 - x) is equivalent to dividing by (-1)(x - 3). For the trigonometric identity problem, the expression √(a^2 - a^2 sin^2 θ) simplifies to √(a^2(1 - sin^2 θ)), which can be factored out as a cos θ. Understanding these steps clarifies the division and identity processes.
Jimmy84
I forgot how to divide this
1.) x^2 + 15 -8x divided by 3 - x
I don't know how to start since 3 has nothing to do with x^2.
The result from the book is 5 - x.
I also don't understand this problem which uses trigonometric identities.
if x = a sin theta then
2.) square rt of a^2 - x^2
= square rt of a^2 - a^2 sin^2 theta
= square rt of a^2 square rt of 1 - sin^2 theta
= a cos theta .
I don't understand why does
= square rt of a^2 square rt of 1 - sin^2 theta ?
Thanks in advance.
1) When dividing, rewrite all the polynomials with highest power of x first, then decreasing powers of x from there.
2) Firstly, we can factor a^2-a^2 sin^2 theta as a^2( 1 - sin^2 theta).
Then we can break up the squareroot using \sqrt{xy} = \sqrt{x} \sqrt{y}.
Thanks by ordering the polynomials and using syntethic division I have 3 dividing 1 -8 +15 which equals x - 5 ?
No. Dividing x2 - 8x + 15 by 3 - x is equivalent to dividing -x2 + 8x - 15 by x - 3.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
