I A double in this example problem
  • I
  • Thread starter Thread starter Muthumanimaran
    Example
Muthumanimaran
I am currently self-studying Mathematical Methods for Studying by Weber, Arfken and Harris. In the chapter Matrix Eigenvalue problems, I'm stuck in a particular step in a particular problem. Please look at the Image attached. The expression which is boxed, $$\frac{F_x}{F_y}\neq\frac{x}{y}$$ in the textbook as we can see, it is said that the force will not be directed toward the minimum at $x=0$ & $y=0$. Actually this is the step I don't understand, how the expression came up here. I am trying to visualize this problem physically, but I am unable to come up with this expression. Please give me some hint or information if possible.
If the ratios are equal it means that the angle of the force can be the same as the angle from the origin to the position (x,y).
$$cot^{-1}(\frac{x}{y}) = \theta_{X} \;\;\;\;cot^{-1}(\frac{F_x}{F_y}) = \theta_{F} $$
$$\frac{x}{y} =\frac{F_x}{F_y}\; \text{implies}\;\theta_{X}=\theta_{F}$$
That is not the case for the given problem, where most of the places the angles are different. Another way of writing this could be
$$\vec{F} \neq f(\vec{r}) \vec{r},\, \text{most } \vec{r} $$
So the force vector is not proportional to the position vector, thus the problem is not a "central force" problem with the center at the origin. So it's different from problems like the Kepler problem of two objects with gravity.
Likes Muthumanimaran
Or otherwise can I say, External torque along $${\hat{k}}$$ direction for a central force is zero. i.e, $$F_x{y}-F_y{x}=0$$, is my reasoning correct?
External torque along ${\hat{k}}$ direction
On this site, use a pair of # symbols at each end (inline LaTeX) or a pair of $ symbols at each end (standalone LaTeX). A single $ at each end doesn't do anything, nor does a single # at each end.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
When decomposing a representation ##\rho## of a finite group ##G## into irreducible representations, we can find the number of times the representation contains a particular irrep ##\rho_0## through the character inner product $$ \langle \chi, \chi_0\rangle = \frac{1}{|G|} \sum_{g\in G} \chi(g) \chi_0(g)^*$$ where ##\chi## and ##\chi_0## are the characters of ##\rho## and ##\rho_0##, respectively. Since all group elements in the same conjugacy class have the same characters, this may be...
