A/F Ratio & BSFC: Q&A to Understand Effects
  • Thread starter Thread starter krish1988
    Ratio
The air/fuel ratio significantly impacts engine output and Brake Specific Fuel Consumption (BSFC), with an optimal ratio enhancing performance and efficiency. BSFC tends to increase at low engine outputs due to incomplete combustion and lower thermal efficiency. As engine output rises, BSFC improves because combustion becomes more efficient and the engine operates closer to its optimal performance range. Injection timing also plays a crucial role; early injection can lead to better mixing and combustion, while late injection may cause increased emissions and reduced efficiency. Understanding these dynamics is essential for optimizing engine performance and fuel economy.
krish1988
I have few questions as i am bit confused
Q1. I want to know what are the influence of the air/fuel ratio on engine output and Brake specific fuel consumption (BSFC).
Q2. why bsfc increases at low engine output?
Q3. why bsfc improves as engine output increases?
Q4. what are the effects of early and late injection timing?
see these posts in this forum...
type in the topics in advanced search ..mech eng forum
Why the engine spins faster when I accelerate?
Aug15-11, 04:41 PM
Horsepower - Please help - Confused!
Feb14-09, 05:36 AM
It wasn't a great help?
What sort of engine are you enquiring about?
i am looking at Ricardo E6 C.I. Engine. I just want to know general influences.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
