A few Electromagnetic questions
  • Thread starter Thread starter Plasma
    Electromagnetic
The discussion revolves around solving electromagnetic problems involving potential difference and induced current. Participants seek assistance with specific parts of their homework, particularly in calculating the potential difference across a resistor and understanding the implications of a changing magnetic field. The current is estimated to be slightly below 9.5 A, and it's noted that as a loop moves away from a wire, the magnetic field strength and flux decrease. The induced current direction is identified as counterclockwise, and participants are encouraged to derive the relationship between induced emf and changing flux. Overall, the conversation emphasizes the need for clarity in calculations and understanding electromagnetic principles.
Plasma
A:
http://i12.photobucket.com/albums/a234/Xuxyz/battery.jpg"
(a) i. Using the information in the graph, determine the potential difference Vo across the resistor immediately after the switch is closed.
Vo = Io * R
I don't know how to find Io using the grap, because as you can see from my link, it doesn't intersect at a specific point.
B:
http://i12.photobucket.com/albums/a234/Xuxyz/04-08-2007015444PM.jpg"
I only need help on part f
I don't know.
None, sorry. I don't have a clue.
C:
http://i12.photobucket.com/albums/a234/Xuxyz/04-08-2007020007PM.jpg"
Only part D
EMF = vBD
I = vBD / R
I know this is a lot, but I would appreciate any and all help.
For number 1, it looks to me like the graph shows a current of about 9.5 A??
*For your second question, what is happening as the loop is moving away from the wire?*
It's actually slightly below 9.5 A
The Magnetic field strength is decreasing.
1. Okay, slightly less than 9.5 A. :rolleyes:
2. So if the field strength is decreasing, what about the flux?
But I need an actual number for the equation to work.
The flux would be decreasing, too?
1. You must use your eyeball.
2. Yes, the flux is decreasing, good. From this, can you tell me which direction is the induced current.
I don't need to know the direction of the current, I need to figure out what it's equal to.
Well, I thought you might want to learn what is happening.
What does a changing flux produce?
The induced current is counterclockwise.
Very good.
But what about it's value?
A changing flux induces an emf around the circuit. Find out the relationship between this emf and other physical quantities.
EMF = the derivative of flux vs time.
So can you quantify how the flux changes?
