A fun trick to see the vasculature of your eye
  • Thread starter Thread starter KingNothing
    Eye Fun
The discussion centers around a video demonstrating a technique to visualize the network of blood vessels in the eye, which typically remains invisible. Participants share their experiences with various methods, including using pinholes to enhance visibility. Some users successfully see a "diffraction pattern" resembling eye floaters, while others struggle to perceive the vessels, attributing their difficulties to conditions like astigmatism or myopia. Key tips include using a bright light source and keeping movements smaller than the pinhole size. The conversation also touches on historical experiments by Isaac Newton and the subjective nature of visual perception, with some participants describing the patterns they see as similar to tree roots or textured images. Overall, the technique's effectiveness varies among individuals, but many find the experience intriguing.
KingNothing
In this video, the narrator explains why you aren't normally able to see the network of blood vessels in front of your eye, and a neat trick to actually see it. I thought it was really cool.
http://www.youtube.com/watch?v=L_W-IXqoxHA&t=3m8s
Haha, very cool. Ever since college I've been using the finger pinhole technique as a lens when I can't quite see something, but didn't know about this one.
Isaac Newton experimented with his own eyes to the point where he could have been blinded.
He would take a narrow dowel and probe near the back of his eye to produce black spots (seemingly opposite to where he was prodding). Part of his "Opticks" research?
I believe all of us have done this to some degree.
Snorting high voltage, yes, but never a poke in the eye. That's nuts!
Whoa, it works!
Trying for 5 minutes on different surfaces (white paper, white wall, white board) under a lightbulb, I see nothing special. :/
I think it works best if you have all the other light blocked out so you're only seeing through a tiny hole. I made the hole in an old hockey ticket, about 1mm in diameter. Try the white background on a computer screen.
Not working for me either... guess I'm not normal. <sigh>
How is it supposed to look like? Like eye floaters? If so, since I suffer from myodesopsia this might explain why I don't notice anything.
I see a faint pattern of squiggly lines around the center of my field of vision. It is subtle but clearly there.
The trick is to
1] aim at a bright source. I'm using a fluorescent ceiling panel.
2] make your movements smaller than the size of the pinhole. So, my pinhole is 1mm, I'm making my movements <1mm.
What isn't clarified is how far from your eye you hold the card, but I'm doing about 3".
Kinda like eye floaters but squiggly lines.
I would call the image I see a "diffraction pattern."
I'm seeing something, I guess it must be it. I use my hands and 1x0.3 cm wide opening approximately. I move the aperture probably a bit more than its size. When I use smaller apertures I see the same thing but light has less intensity due to diffraction I think so a huge aperture works fine. Even a 1x1 cm aperture work although better around the edges.
I wish the brain would stop to "see" eye floaters too.
Wow that's awesome. I did it and I could see a textured relief-like image very clearly - you can even kind of follow the pattern by turning your head a little so the light is coming in at slightly different angles.
doesn't work for me, I think to too severely astigmatic and myopic
This explains what I've been seeing. It looks like a rosette where only the wavy tips of the open rose are traced in a light gray. I see that every day.
I think it shouldn't matter, it is not about where the light is getting focused.
Oh wow, that is awesome. I don't know if it is because I am very farsighted, or if that doesn't matter, but I immediately see the entire network of vessels. ; I could draw a complete map if I needed to.
Still can't see it. I wonder if it has anything to do with my needing glasses to see anything up close?
It shouldn't. It's occurring independent of the focus. i.e. it's equivalent to placing objects directly on an unexposed film under a light.
That was my conclusion also; anyway, I'm extremely far-sighted (near point is 50 feet), and I saw the vasculature immediately. Bright back light & not too tiny pinhole. The fingle-pinhole he demonstrates works well. I rested my finger knuckle on my forehead and moved it as though I was massaging my eyebrow. Making circles not-as-big as the aperture is key.
hmmm, I'll try again some other time.
I remember once I had a major greyout just before my vision was completely gone (temporarily) I was seeing lines like tree roots in my field of vision. Could that be the same thing?
Tree roots is not a bad description of the vasculature looks like.
Note: glasses shouldn't mean anything, I guess you will get correct results without glasses. As I said before, it is not about where the light is focused, it is about shadows dropped by the veins that are almost touching the retina.
Is the pattern like that of the retina from an ophthalmologist's light?
Yes.
