A GRAVITATIONAL POTENTIAL ENERGY questions
The discussion revolves around calculating the work required to move a satellite from an orbital radius of 2r_e to 3r_e, focusing on gravitational potential energy and kinetic energy changes. Participants debate whether kinetic energy should be considered in the calculation, with one user expressing confusion over the book's method, which only accounts for potential energy. The relevant equations for gravitational and kinetic energy are shared, leading to a derived formula for work based on energy differences. The conversation also touches on the implications of orbital mechanics and the relationship between velocity and work done during the satellite's movement. Ultimately, the consensus is that the book's approach is valid, emphasizing the importance of understanding energy states in such problems.
rootX
determine the amount of work required to move a satellite from orbital radius of
2r_e (twice the radius of the earth) to 3r_e, if it has a mass of 500 kg?
Find change in Gravitation potential energy
and also the change in the kinetic energy
The solution is the book does not consider the change in the kinetic energy. Shouldn't it be considered as velocity is decreased when it moves to a higher orbit
What is the relationship between either Work or Potentential energy and Kinetic? You didn't show your relavant equations. Show your attempt also
it's simple though
W = change in U + change in E_k
<I solved that question using this method>
and, the book solved it using
W= change in U
yea, i didn't show my work because I have the solution provided in the book, so I am just confused about how the book solved it
what is the relationship between potential energy and kinetic? Would it make a difference if you write the change in potential or change in kinetic? It applies to what kind of question you are solving. You did not give us the exact problem you are asking, you did not give us all the relavant equations, you did not show us any of your work. Do you want to solve the problem?
hmm.. certainly
so, here's my exact question:
as for relevant equations <they are just too messy>
E_k = 0.5mv^2
E_g = - (GMm)/r
and here's the attempt
Work = - (GMm)/r_f + - (GMm)/r_i + 0.5mv_f^2 - 0.5mv_i^2
v^2 = GM/r
0.5mv^2 = 0.5xGMm/r
so
Work = - (GMm)/r_f + (GMm)/r_i + 0.5(GMm)/r_f - 0.5(GMm)/r_i
Work = -0.5(GMm)/r_f + 0.5(GMm)/r_i
so, it is equal to 0.5(GMm)[1/r_i - 1/r_f]
so this is how i did it
but the book did it this way
rootX said:
hmm.. certainly
Looks like the book did it correctly, Work is the difference between two energy states. Is that clearer? Work is transfer of energy. So you can say it is the difference of two inergy states. initial and final. How much work does it take to lift a object vertically up? Did the object change in potential energy? Also, when you look at a problem, see what they give you, and that is all you know. Given what they gave you, is it most logical to solve it the book way?
yea,i understand the concepts of work
but isn't this situation different, because initially the object is moving perpendicular to the applied force, and in its final state, it moving with a lower velocity, thus this decreased the kinetic energy. This happens along with the change in the gravitational potential energy.
Read the question carefully, it says to move the satillite from one position to another. Did the problem give you velocity? If want to solve it using work-kinetic, be my guest. If they didn't give you the right pieces of the puzzle, how can you solve it?
I solved for v using that equation
Centripetal force = gravitational force
(mv^2)/r = (MmG)/r^2
<cuz it's orbiting>
anyhow, now I got the question --> "from one position to another."
now, this is my second question
Prove that “No satellite can orbit Earth in less than about 80 min”?
yes, i can do this numerically, and I have done that, and it gives minimum time of 85 min
But, since they didn't mention anything about forces, so anyone can supply more downward force<towards the center of the earth>, so as to lower the time period.
<cuz it's orbiting>
Yeah, but that is velocity in its orbit. That is not radial movement. Radial positions. Distance from earth. Let's say you are running with velocity and holding and object on top of your hand, you lift it up. is it the same amount of work if you were not in motion? Work on the object.
