How to Solve a Logic Problem with Numbers Using Equations?
  • Thread starter Thread starter mhill
    Logic Numbers
To solve the logic problem involving the numbers ABCD and CDAB, the equation 2(ABCD) = CDAB - 5 can be restructured by letting X = AB and Y = CD. This leads to the Diophantine equation -199X + 98Y = 5, which has an infinite number of integer solutions. However, only one solution will yield two-digit positive integers for both X and Y. The discussion emphasizes the need for a more elegant approach rather than brute force methods. Understanding the relationship between the digits and their positional values is crucial for finding the correct solution.
mhill
given a number of four ciphers ABCD and another four cipher number CDAB get the values of A,B,C,D if we know that 2x (ABCD)=CDAB-5
2X (ABCD)=CDAB-5
no idea.. i have try by brute force but got no results only incongruences , for example B=-3 or similar here '2 x' means multiplication
You need to be a bit more elegant about this. Split it into powers of ten... for example in the ABCD cipher, the "A" is 100 times more value than the "A"
no way , i get weird responses such us A=c=0 and B=-5/3 how are these kind of problems solved in Number theory ?? thanks.
2X (ABCD)=CDAB-5
Notice that AB and CD always appear together. I would do it this way:
Let X= AB and Y= CD. Then the equation says 2(100X+ Y)= 100Y+ X- 5. Combining the X and Y terms we get the Diophantine equation
-199X+ 98Y= 5. Do you know how to solve that? It has an infinite number of integer solutions but only one that gives a two digit positive integer for both X and Y.
This looks quite similar to https://www.physicsforums.com/showthread.php?t=230969 by the way.
Very similar! That's why I deleted that thread.
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
