A Lot of Basic Question About Lorentz-Minkowski Geometry
  • Thread starter Thread starter nomather1471
    Geometry
nomather1471
Hi there, i have a lot of question about Lorentz-Minkowski geometry:
1)
Is Lorentz metric degenere or non-degenere? Why?
2) In spacelike subspaces only spacelike vectors live in it there is not problem here but how can
we say that timelike subspaces include null and spacelike vectors and lightlike subspaces include
spacelike vector?
3) Let E1 spacelike and E2 timelike vector then E1+E2 is null vector, proof...?
4) If Sp{E1,E2} spacelike, Sp{E1,E3} and Sp{E2,E3}
are timelike planes Sp{E1,E2+E3} is lightlike plane?
5) E1+E2+E3 is spacelike vector but
Sp{E1,E1+E2+E3} is lightlike plane?
6) E2+E3 is lightlike vector but Sp{E2+E3,E3} is timelike plane?
That is a lot of questions.
This is not true in general. In units where c=1 and using the (-+++) signature, then the sum of
E1=(0,1,0,0) and E2=(1,0,0,0) is null
E1=(0,1,0,0) and E2=(5,0,0,0) is timelike
E1=(0,5,0,0) and E2=(1,0,0,0) is spacelike
Hopefully other people will address the other questions.
DaleSpam said:
That is a lot of questions.This is not true in general. In units where c=1 and using the (-+++) signature, then the sum of
Thanks, i agree with you, these questions are from the Rafael Lopez Minkowski Lectures, about question 3 the author able to think the unit vectors, the original is E2+E3 is null so if we take E2=(0,1,0) and E3=(0,0,1) then E2+E3=(0,1,1) which is a null vector, here the signature is (+,+,-) in E13...
1)
It's non-degenerate, because the representing matrix (\eta_{\mu \nu}=\mathrm{diag}(1,-1,-1,-1) (sorry for changing the convention within the thread, I'm used to the west-coast convention; if I'd change it, most probably I'd get confused myself).
nomather1471 said:
2) In spacelike subspaces only spacelike vectors live in it there is not problem here but how can we say that timelike subspaces include null and spacelike vectors and lightlike subspaces include spacelike vector?
I don't know, what you mean by "subspace". In the usual sense of subspaces of a vector space, indeed there exist three-dimensional subspaces of time-like vectors. They can be defined as to be 3D subspaces Minkowski-perpendicular to an arbitrary time-like vector.
Proof: Let n a time-like unit vector, i.e., n \cdot n=\eta_{\mu \nu} n^{\mu} n^{\mu}=1. Then you can build the following Lorentz transformation
({\Lambda^{\mu}}_{\nu})=\begin{pmatrix}<br /> n^0 &amp; \vec{n}^t \\<br /> \vec{n} &amp; 1+\frac{n^0-1}{\vec{n}^2} \vec{n} \otimes \vec{n}<br /> \end{pmatrix}<br />
in obvious notation. Then
E_0&#039;=n=\Lambda E_0, \quad E_j&#039;=\Lambda E_j
build a new Minkowski-orthonormal system, and \text{span}(E_1&#039;,E_2&#039;,E_3&#039;) is a 3D subspace containing only space-like vectors.
On the other hand subspaces with only time-like vectors are necessarily one-dimensional, because suppose you have two linearly independent space-like vectors n_1 and n_2 you can construct the vector
a=n_1-\frac{(n_1 \cdot n_2)}{n_2 \cdot n_2} n_2 \neq 0
within the subspace. It's Minkowski-perpendicular to the space-like vector n_2, but then it must be either spacelike or lightlike.
To prove this you just take a \cdot n_2=0 and write it out in components
a^0 \cdot n_2^0-\vec{a} \cdot \vec{n}=0 \; \Rightarrow \; |a^0|=\frac{|\vec{a} \cdot \vec{n}|}{n^0} \geq \frac{|\vec{a} \cdot \vec{n}|}{|\vec{n}|} \geq |\vec{a}|,
and thus
a \cdot a=(a^0)^2-\vec{a}^2 \leq 0.
In contradiction to the assumption the subspace necessarily contains at least one spacelike or lightlike vector. In conclusion, subspaces that contain only time-like vectors are one-dimensional.
is wrong as shown by the counter example by DaleSpam as are the other claims, or are their additional restrictions on the vectors E_j?
Sorry but i can't understand anything with physics notation, i think Lorentz metric be a non-degenerate because of the definition of degenere metric...I mean subspaces by subset of Lorentz space, timelike subspaces are space which has a non-degenerate metric on it and lightlike subspace are space which has a degenerate metric and different from {0}, but how can we guarantiate the lightlike space has a spacelike vector, our teach told this with tangent plane to the timeconi but i am not sure of the truth, the question is if any subspace contain null vector is this set must be a lightlike subspace?
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
