A photocell device to light a small bulb
  • Thread starter Thread starter wdavidleeii
    Bulb Device Light
This discussion focuses on building a photocell device that activates a small light bulb, specifically a flashlight bulb, using a laser pointer as the trigger. The user seeks guidance on the necessary components, including a photocell, batteries, and circuit design. The recommended approach involves inverting a standard nightlight circuit using a simple transistor or comparator to achieve the desired functionality. Experimentation is emphasized to ensure the circuit operates as intended, particularly regarding the sensitivity of the photocell to the laser pointer.
  • Basic understanding of Ohm's Law
  • Familiarity with circuits and electrical components
  • Knowledge of phototransistors and LEDs
  • Experience with simple circuit design and modification
  • Research phototransistor functionality and specifications
  • Learn about LED circuit integration and power requirements
  • Explore nightlight circuit designs for modification
  • Experiment with different photocell types and their sensitivity
This discussion is beneficial for electricians, electronics enthusiasts, and hobbyists interested in building custom light-activated circuits using photocells and laser pointers.
wdavidleeii
Hello, this is my first post. I googled it, and searched the forums, but no luck.
I want to know what I need to build a device, that can light a small light bulb. Something rather small, such as a flashlight bulb. But I need the on/off switch to be a photocell that is sensitive enough to make the bulb light, when a laser pointer hits it. If that doesn't make sense, think of it this way. I want a to make a small light bulb light up whenever the laser pointer is hitting the photocell.
I assume I need a few batteries to light the bulb. Also, a photocell of some kind, but I don't know what kind. Would I need anything else?
If I need to be more specific about anything let me know.
Thanks in advance.
Start with a nightlight circuit and flip the logic (a simple transistor should do), or you could use a comparator and flip the pins.
Okay. I guess I should have stated that I am not an electrical engineer, nor do I have very much knowledge on the subject. I am an electrician's apprentice, and I understand ohm's law and comprehend circuits. But I don't know what a logic is, or a comparator is either.
Also, exactly what would that do? Would that make it so the photocell from the nightlight is switched on when light hits it, or what?
Thanks
Yes - currently nightlights turn the light on in the absence of light.
You want a circuit that will do just the opposite.
Essentialy, you just want to invert the signal of a the circuit.
The approach I was giving you was a simple way to hack something you could inexpensively obtain.
The question becomes, do you want to build something, or hack something you can buy?
If you want to build something, I would read on phototransistors and LEDs. That more/less is all you'll need to build your circuit (assuming you have DC power available).
It seems that you've got some interest in electronics, which is a good start. If you Google night light circuits, you might be able to find something with a full circuit description you can build with a few minor tweaks.
Right. So do you think a laser pointer would be a strong enough source of light to make it work? Do you think it depend at all on the light around the photocell relative to the brightness of the laser? Am I going to have to experiment? Sorry for all the questions. I just have a very specific idea and I want to build it but I don't know exactly how to begin.
The laser pointer should be plenty good. It is far brighter then the nominal ambient lighting in a room (which it currently responds to).
You should always experiment to find out though. It is better to know something will work, than to construct a circuit and hope it works.
  • · Replies 22 ·
