MHB Help With Probability Problem: Find Mean & Variance of Vn
  • Thread starter Thread starter Mike2323
    Probability
The discussion revolves around calculating the mean and variance of the number of successes, Vn, in a scenario where n people randomly select their identities from a box. The probability of k individuals picking their own identity is derived from permutations, leading to specific calculations for n=2 and n=3, both yielding an expected value (mean) of 1 and a variance of 1. The user notes a consistent pattern emerging, suggesting that for larger n, the mean and variance may also equal 1. This insight indicates a potential generalization for the problem across different values of n. The conversation highlights the mathematical approach to solving probability problems in combinatorial contexts.
Mike2323
Hello and i need your help with the following statistic ploblem!
in a party there are n people (n >=2). each man cast identity in a common box.They mix and each person chooses identification at random from the box, without resetting. We say that we have success if one chooses his identity. If with Vn denote the number of successes, find the mean and variance of Vn
A tried to use Gambler's Ruin and i don't know if i get something the answer
I made this think
Pn=0 n=0
Pn=1 N=1
PPn+1+(1-P)Pn-1 (for 0<n<N)Please, if someone could help me i would appreciate it since i didn't answer this problem in an old test!
THank you so much with your time!
Mathematics news on Phys.org
I made this think
Pn=0 n=0
Pn=1 N=1
Hi Mike2323! Welcome to MHB! ;)The probability that $k$ persons in a group of $n$ pick their own identity is given by:
$$P(V_n=k)=\frac{\text{#Permutations that leaves $k$ of $n$ identities the same}}{\text{#Permutations of $n$ identities}}$$
where \(\text{#Permutations of $n$ identities}=n!\).For $n=2$ either the identities are swapped, or they are not.
So $P(V_2=0)=\frac{1}{2!},\ P(V_2=1)=\frac{0}{2!},\ P(V_2=2)=\frac{1}{2!}$.
That gives us the expectation:
$$E_2 = \frac 12 \cdot 0 + \frac 12 \cdot 2 = 1$$
and the variance:
$$\sigma_2^2 = \frac 12 \cdot (-1)^2 + \frac 12 \cdot (1)^2 = 1$$
For $n=3$ either the identities are cyclically shifted (2 possibilities), or 2 identities have been swapped (3 possibilities), or everyone gets their own identity (1 possibility).
So $P(V_3=0)=\frac{2}{3!},\ P(V_3=1)=\frac{3}{3!},\ P(V_3=2)=\frac{0}{3!},\ P(V_3=3)=\frac{1}{3!}$.
$$E_3 = \frac 26 \cdot 0 + \frac 36 \cdot 1 + \frac 16 \cdot 3 = 1$$
and the variance:
$$\sigma_3^2 = \frac 26 \cdot (-1)^2 + \frac 16 \cdot (2)^2 = 1$$
I think I'm seeing a pattern here...
If I do the same thing for $n=4$ and $n=5$, I'm getting again that $E=1$ and $\sigma^2=1$... (Thinking)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
15K
