A Question about the Domain and Range of a Function
student34
I constructed my own question to try to make sense of the following notation.
g(x) = 2√x g : X → Y. What does X and Y equal?
For 2√x, x = or > than 0.
g(x) = 2√x g : [0, ∞) → [0, ∞)
So X = Y = [0, ∞)
The reason why I am doing this is because my book shows this: g(x) = 2√x g : [1,∞) → [2,∞). Why does my book have a 1 instead of a 0 as an initial x value?
So X = Y = [0, ∞)
You have found the LARGEST domain that that function can be defined on. X could always be defined to be a subset of that domain, in which case your job is to figure out the corresponding Y. Are you sure the book didn't tell you X=[1,∞)??
The book just shows this, "g(x) = 2√x g : [1,∞) → [2,∞)" as an example of, "g : B → C". I just used X and Y for this thread.
The book could also have said correctly that "g(x) = 2√x g : [4,∞) → [4,∞)". That would work also, right? Nothing in the problem really fixes what X HAS to be.
Oh, I see, thank-you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
