How to Prove Mass Invariance in Relativistic Collisions?
iacephysics
This is a question on special relativity from Taylor's Classical Mechanics.
Consider an elastic head-on collision between a projectile, with mass m1 and velocity v1, and a stationary target of mass m2. So, in the lab frame, the target m2 is at initially at rest and mass m1 moves toward it with v1. In the center of mass frame, m1 and m2 move toward each other with equal and opposite momentum. Taylor says the only effect of the collision is to reverse the three-momentum of each particle (in CM frame), which means m1's mass is still m1, and m2's mass is still m2, there is no change of the particle's mass. How do you prove this relativistically?
Well i would show that the invariant mass is an invariant with respect to lorentz transfomation, and use 4vectors.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
