A small problem with complex conjugations
  • Thread starter Thread starter Parnpuu
    Complex
The discussion centers on the understanding of complex conjugations in equations involving complex numbers. The equation zz* = (a2 + b2) is clarified as correct without the need for an imaginary unit, as z* represents the conjugate of z. The participant explains that when multiplying a complex number by its conjugate, the result simplifies to a real number, specifically a² + b². This highlights that the imaginary part cancels out during the multiplication process. The explanation resolves the initial confusion regarding the absence of an imaginary number in the equation.
Parnpuu
Hi!
I have a problem with understanding an equation which is really simple.
zz*=(a2+b2)
shouldn't there be an i there if
z1z2=(a1+ib1)(a2+ib2)
is the equation correct?
If it is could someone explain to me why there is no imaginary number?
Thank You!
Mathematics news on Phys.org
if z = a + bi, then z* (conjugate of z) = a - bi so
(z)(z*) = (a+bi)(a-bi) = a2 - (bi)2 = a2 -(i)2b2 = a2 -(-1)b2 = a2 + b2
Yes I can see that now.
Thanks!
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
