A spring is attached to the ceiling by a string with no weights
  • Thread starter Thread starter vstrimaitis
    Spring String
The discussion revolves around a spring system attached to the ceiling by a string, focusing on the spring's constant and the period of oscillation when no additional weight is applied. The problem involves understanding the behavior of the spring under these conditions and the implications of its mass and unstretched length.
  • The original poster attempts to determine the spring constant (k) and the period of the system, questioning how the absence of a weight affects the calculations. Some participants suggest visual aids to clarify the setup, while others propose considering the spring's mass and how it influences the overall behavior.
Participants are actively engaging with the problem, offering suggestions for visual representation and discussing the implications of the spring's mass on the calculations. There is a focus on breaking down the system into manageable parts, but no consensus has been reached on the approach to take.
The original poster notes a lack of experience with similar problems where no weight is attached to the spring, indicating potential gaps in understanding how to apply concepts in this specific scenario.
vstrimaitis
1. A cylindrical string is made out of thin wire.
  • The distance between every loop of an unstretched spring is equal;
  • The radius of every loop of the spring is r = 4 cm;
  • The length of an unstretched spring is l = 20 cm;
  • The mass of the spring is m = 50 g;
The spring is hung on the ceiling by a non-elastic string which has a length of a = 10 cm. When the string is hanging, it has the length of l' = 25 cm.
2.
  • What is the constant of the spring (k)?
  • What is the period of this system, if the angle, at which it is released, is small?
3. I haven't really solved any problems when the weight is not attached on the end of the spring. Does it work the same way or not? If it does, I'll be able to find k. But I have no idea what to do with the period... Any help at all would be appreciated ^^
Please add a sketch of the system. It is hard to visualize this based on your post.
If something is connected to a point within the spring, you can split the spring in two pieces and consider them as two springs.
I hope this will clarify the problem at least a little bit.
Then you'll have to consider the weight of the spring. For a length x in the unstretched spring (where you need some definition of x), what is the mass below that point? What is the stretching force there? If the total spring has a constant of D, what can you say about each point, and finally the stretching of the whole spring?
  • · Replies 18 ·
  • · Replies 27 ·
10K
  • · Replies 20 ·
