A stab wound from a single edged weapon. How to identify?
  • Thread starter sameeralord
    Wound
3 replies · 10K views · last reply
sameeralord
Hello,
Here is single edged knife.
Labelled diagram of a single-edged knife from CustomTacticals.com: top view shows blade tip, spine, ricasso, bolster, mosaic pin, choil, subhilt, handle, butt and blade belly; lower view shows spine and tang.
Consider
spine= blunt end
blade belly = sharp cutting edge
Here is the wound
Close-up photo of a narrow, elongated wound on yellowish skin, with a sharply pointed end on the left and reddened, slightly open edges.
Now the really pointed end at the left side of the wound, is it created by blade tip or the blade belly (sharp cutting edge). This might be obvious but I'm bit confused at how this wound is created, when I look at double edged wounds. Thanks :smile:
Two slit-shaped stab wounds in grey clay or soft material, with two knife blades pressed against the lower part of the image; the left wound is a pointed-ended slit and the right is more elongated.
Double edged left, single edged right.
Is this for forensics analysis of knife wounds?
Your motive might be questioned if there is any legalities involved.
A knife can be used to stab, slash, or cut.
Subsequently, the wound can be either a stabbing wound, a slashing wound or an incised wound.
You have to check depth and length of wound to narrow further down.
sameeralord said:
Hello,Consider
spine= blunt end
Here is the wound
Close-up photo of a narrow, elongated wound in skin, red and slightly open, with pointed ends and a pale, smooth surrounding area.
Two knife stab wounds in grey clay, each a narrow slit with pointed ends, with two knife blades pressed into the clay below them.
Do you mean this wound looks double-edged to you?. It was created from a single edged knife, as you can tell from the sharpness of the nearer extremity of the wound. Perhaps you were thinking one wound edge should be more ragged, but the skin has separated and wound edges have become more stretched out, reducing the contrast between the two edges. You don't see this in clay. If you looked at this under magnification, I think you could tell the difference between the wound edges.
It appears to have been created with a small single edge knife. The puncture doesn't look very deep. Some adipose tissue appears to be visible.
