A thought experiment on gravitation
The thought experiment explores the implications of dropping a mass into a deep well on a large planet with a defined acceleration. As the mass falls, it accelerates due to gravity, but it cannot reach the speed of light, which is 3x10^8 m/s. The gravitational potential energy between the surface and the center of the planet is finite, resulting in a finite kinetic energy that limits the mass's velocity. As the mass approaches the speed of light, increasingly more force and energy are required to continue accelerating it. Ultimately, while the mass can get very close to the speed of light, it can never actually reach or exceed it.
physio
A thought experiment on gravitation...
Let us suppose we have a very large planet X which is assumed to have some acceleration 'a'. Suppose we keep on digging a well and afterwards we drop a small mass 'm' then due to the force there will be an acceleration. As acceleration is change in velocity with change in time hence the velocity keeps on increasing as the ball falls further down then is it possible that the mass 'm' will acquire the velocity of light 3x10^8 m/s?? If not then why (the body is accelerating)? If it will then what happens next, as in can it go any faster than light??
Regardless of how large the planet is its mass is finite. Therefore the difference in gravitational potential energy between the surface and the center is finite. So the object will gain a finite amount of KE. Any finite KE will have a veocity less than c.
More general, a constant force in your lab system does not give a constant acceleration (this is just a nonrelativistic approximation for low velocity) - as soon as the object gets close to the speed of light, you need more and more force and energy to increase its velocity. You can get as close to the speed of light as you want, neglecting technical issues, but you can never reach it.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
