Can a Riccati-type Differential Equation with a Square Root Term be Classified?
Elros
Hi Folks..I came up with a weird looking DE for my research
Q''[t] = f[t]Q'[t] + g[t]Q[t] + h[t]*Sqrt[(Q[t])^2 + (k[t]Q'[t])^2]
The thing that mixes my mind is the square root term..If there is no square root terms it would like a riccati type..but there is..i tried to google it but it just showed me bunch of papers about fractional power DEs which is different...Is there any classification for this type ?
Thanks..
Common any ideas ?
Actually, setting:
Q(t)=e^{\int_0^t dx G(x)}
reduces your 2nd order ODE to a 1st order nonlinear one:
G'(t)=-G(t)^2+f(t) G(t)+g(t)+h(t) \sqrt{G(t)^2 k(t)^2+1}
Depending on the form of the functions f(t),h(t), g(t) and k(t) you might be able to solve the latter and then again it might be worse...
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
