ASTM A1011 CS Type B Steel: Yield Strength & Properties
  • Thread starter Thread starter Satonam
    Cs Steel Type
The discussion highlights concerns regarding the yield strength variability of ASTM A1011 CS Type B steel, which ranges from 30 to 50 ksi, and the lack of mandatory physical property standards from suppliers. This raises questions about the reliability of these materials in critical industries like automotive and aerospace. The conversation suggests that while chemical composition is easier to control, the variability in mechanical properties poses challenges for engineers. A workaround proposed includes assuming a conservative yield strength of 30 ksi for simulations, although other mechanical properties are still needed for accurate modeling. It is noted that the elastic modulus is generally consistent across steel types, simplifying some aspects of material testing.
Satonam
I'm currently working on a design project which requires using sheet metal with ASTM A1011 CS Type B steels. Reading their latest designation for this type of steel, it is shown that the yield strength varies between 30 - 50 ksi. [1] Maybe it's just because I'm new and naive, but I find this variation very alarming considering that our current manufacturer can't provide the mechanical properties of the steels they use in our products. According to Alro Steel, suppliers of this type of sheet metal are only required to meet chemical standards but ensuring consistent physical properties aren't mandatory. [2] How is that allowed and how do engineers trust these materials when used in the automotive and aerospace industry? My impression is that controlling the chemical composition of the steel is much easier and more affordable than controlling its properties, is this assumption correct?
As a work around to this problem, I'm considering taking the lower extreme and assume all our steels are at 30 ksi. With that said, I would still be missing other mechanical properties, such as poisson's ratio, the elastic modulus, shear modulus, etc. -which I need in order to perform reliable simulations on Solidworks. I guess I can find the elastic modulus with an empirical test by relating the measured deflection of a beam, but at that point, it's probably cheaper if we sent it to a third party for testing (as suggested by Alro Steel).[1] https://compass-astm-org.libdb.njit.edu:8443/EDIT/html_annot.cgi?A1011+18a#s00022
[2] https://www.alro.com/divsteel/Metal...1/A1018 CS Type B&Mat=CARBON STEEL&Type=Plate
The 30 KSI yield sounds about right for a hot rolled very low carbon steel. It will increase with work hardening, such as by cold rolling. Increasing yield strength by cold working also reduces ductility. Cold rolled steel can be annealed to increase ductility, with the side effect of reducing yield strength to 30 KSI.
The SolidWorks default properties for hot rolled mild steel should work well enough.
As for elastic modulus, steel is steel. All steels have the same elastic modulus. Highly alloyed steels, such as stainless steel, have a slightly lower elastic modulus.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
