Abbreviation on material properties help -- what is h_ET, h_h, vP, V epspkt?
The discussion revolves around the clarification of specific parameters related to a material model, including E-modul, yield stress, and various coefficients. h_ET likely refers to the elastic modulus in a viscoelastic context, while h_h may denote a characteristic related to viscosity. vP is probably the letter v, which could represent Poisson's ratio, and V epspkt likely indicates a volumetric strain parameter. The user seeks to confirm the units for E-modul, questioning if it is indeed 2000 MPa. Overall, the conversation focuses on understanding the definitions and units of these material characteristics in modeling.
WIN
material A:
E-modul:2000
yield stress:50MPa
h_ET:99
h_h:200
vP:20
V epspkt:0.99
parameter used for material characteristic curve n building of material model - (linear elastic, elastic plastic and viscoplastic model)
can someone explain to me what is h_ET, h_h, vP, V epspkt?
From the look of "epspkt" this is probably not in English. Can you provide units where there are any, e.g. is "E-modul" 2000 MPa? Is h the letter h or the Greek eta (η), a common symbol for viscosity? Is v the letter v or the Greek nu (ν), a symbol for (among other things) Poisson's ratio?
Hello! I've been brainstorming on how to prevent a lot of ferrofluid droplets that are in the same container. This is for an art idea that I have (I absolutely love it when science and art come together) where I want it to look like a murmuration of starlings. Here's a link of what they look like: How could I make this happen? The only way I can think of to achieve the desired effect is to have varying droplet sizes of ferrofluid suspended in a clear viscous liquid. Im hoping for the...
Hello everyone! I am curious to learn how laboratories handle in-house chip manufacturing using soft lithography for microfluidics research. In the lab where I worked, only the mask for lithography was made by an external company, whereas the mold and chip fabrication were carried out by us. The process of making PDMS chips required around 30 min–1 h of manual work between prepolymer casting, punching/cutting, and plasma bonding. However, the total time required to make them was around 4...
