About null and timelike geodesics
  • Thread starter Thread starter Astronomer107
    Geodesics
Null geodesics are paths that light and massless particles follow, while timelike geodesics represent the paths that massive objects can take through spacetime. A geodesic is defined as a path of extremal length, not necessarily the shortest, between two points in a given space, which can vary based on the metric used. For example, multiple geodesics can exist between two points, such as a straight line and a helical path on a cylinder. The concept of geodesics is crucial in understanding the geometry of spacetime, especially in the context of general relativity. Understanding these distinctions is essential for grasping the principles discussed in works like Hawking and Penrose's "The Nature of Space and Time."
Astronomer107
Can you explain a little more about null and timelike geodesics (I think that's how you spell it)? I was reading Hawking and Penrose's The Nature of Space and Time, but it got a little technical. I would really like to know more about these though... thanks!
To put it simply, a null geodesic is a path light can take, a timelike geodesic is a path everything else can take.
a geodesic is a the shortest path from point to point in a specific space, i.e. straight line on a piece of paper, a curve on a sphere
timelike means future pointing.
timelike geodeise is the shortest path an object can travel from event A to event B in spacetime.
hope this is right or i'll fail my exam in 2 weeks time...
Likes Photonnnn
You're right, but don't forget Null Geodesics. These are the ones that only light (and massless particles) can follow. It was a null geodesic that the light followed in Eddington's 1919 observation of light shifting near the Sun. Also "shortest time" for a geodesic should be replaced with "stationary action" - but perhaps your course hasn't got to that yet.
I wrote up a web page on this a while back. Its located here
http://www.geocities.com/physics_world/ma/geodesic.htm
There are three basic ways to obtain the geodesic equation that I know of and so I posted those three derivations.
Please note that a geodesic is not defined as the shortest path from one point to another. It's a path of extremal length (where length has a meaning defined by the metric). There may be multiple paths between the same two points which are geodesics and each may have a different length.
Consider the cylinder r = R. Let the z-axis be the axis of the cylinder. consider the two points.
Point 1: r = R, theta = 0, z = 0
Point 2: r = R, theta = 0, z = b
The straight line from Point 1 to Point 2 is a geodesic. However the helix
x(t) = R cos(t) i + R sin(t) j + (b/2*pi)t k
is also a geodesic. See Figure 4 at
http://www.geocities.com/physics_world/euclid_vs_flat.htm
Notice that there are an infinite number of geodesics between those two points. You can define a helix which has one end at Point 1 and hich coils around the cylinder N times before passing through Point 2 where N is an arbitrary integer. And of course there are two helices for each end which differ only in the direction that it winds.
If you were to draw each of these curves onto the clyinder and cut the cylinder along its length then lay it out flat then each curve would be a straight line.
Think of a geodesic as the straightest possible curve.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
