? about Soldering Iron Tip Care
  • Thread starter Thread starter meBigGuy
    Iron Soldering
Using a Weller WTCP soldering station, users are concerned about the lifespan of new lead-free tips. To extend the life of these tips, it is recommended to use the lowest temperature that effectively melts solder and to wipe the tip on a soft sponge, ideally dampened with a glycol coolant to maintain moisture and temperature. While stainless steel wool can be used on bare copper tips, it is detrimental to WTCP tips due to the removal of protective plating. The use of traditional 60:40 Pb-Sn solder can help preserve the tips, as ROHS Pb-free solder is not mandatory for certain applications. Keeping a stock of reasonably priced WTCP tips is advisable, as they are effective and cost-efficient despite wear over time.
meBigGuy
I have a Weller WTCP station (antique) that I just bought new tips for. I read in some tip reviews that the new "lead-free" technology has ruined the lifespan of tips. Does anyone have any tricks or hints to lengthen the lifespan of these new tips? Any process that can improve the tip? Any tricks you do to keep them functional longer (beyond turning the iron off).
Use the lowest temperature tip that will fully melt the solder.
Wipe the tip on a soft sponge to remove excess solder. I wet the sponge with 50% glycol coolant which is hygroscopic, so it is always available and does not dry out. Low water content in the sponge preserves the temperature of the tip while wiping.
A soft sponge will not damage the tip. Stainless steel wool works OK with bare copper tips, but it will remove the protective plating and destroy a WTCP tip.
You can often use the old 60:40, Pb-Sn eutectic solder, preferably with a tad of Cu to preserve the tip.
ROHS Pb free solder is not required for prototyping, critical process control or data communication equipment.
WTCP tips are available at reasonable prices, don't pay the RRP, you can often do better. Keep a few in stock. They work well, so what if they wear out, they easily pay their way.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
