About solving heat equation in half plane
The discussion centers on solving a heat transport equation in the frequency domain for a semi-infinite domain. The user initially attempted to use polar coordinates and Bessel functions but encountered divergence issues. A suggestion was made to apply the Laplace transform with respect to the y-dimension, which would yield an ordinary differential equation (ODE). However, the user expressed concerns about determining the coefficients from the boundary conditions and the complexity of performing the inverse Laplace transform. Overall, the conversation highlights the challenges in solving the equation while considering boundary conditions and transformation methods.
diraq
Hi guys,
I have trouble when solving the following heat transport equation in half plane in frequency domain.
(\frac{\partial^2}{\partial x^2}+\frac{\partial^2}{\partial y^2})\theta(x,y)=i\beta\theta(x,y),-\infty&lt;x&lt;+\infty,y\geq 0;<br /> \theta(|x|\rightarrow\infty,y)=\theta(x,y\rightarrow\infty)=0;<br /> \frac{\partial}{\partial y}\theta(x,y)|_{y=0}=f(x),
where i=\sqrt{-1} is the unit of imaginary number, \beta is a positive real constant, f(x) is a real function.
I tried to solve it in polar coordinate. \theta can be expanded as the sum series of Bessel function of the second type, K. But the problem is K is divergent around the origin.
I really appreciate any help from you guys. Thanks.
Science news on Phys.org
since your domain is semi-infinite in the y dimension and you have a boundary condition at y=0, I would try Laplace transform wrt y. Should give you an ODE you can deal with.
good luck.
jason
You are right. It can be converted to an ODE using Lapace transformation. But the difficulty is transported to using the boundary condition to determine the coefficients which depends on the Laplace variable s. Plus, even if the coefficients can be determined, I need to do the inverse Laplace transform to get the final result, which is almost equally changeable.
Thanks anyway.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
