jens.w
- 11
Given that \epsilon> 0, why is it, that \left | x_{n} -L\right |< \epsilon implicates that x_{n} > L-\epsilon ?
mtayab1994 said:Well if: l Xn-L l ≥0 then you can remove the the absolute value.
jens.w said:Homework Statement
Hurkyl said:Try some examples to get a feel for it.
Since you're dealing with absolute values, you could always use the usual technique for dealing with them: split into two cases depending on whether the argument is positive or negative.
jens.w said:Yes, i thought of that at first, but it doesn't help in this case since x_{n}-L can be either positive or negative at all points, or alternating, depending on what series x_{n} is a part of. So based on that, i can't exclude one of the cases via the definition.
It doesn't matter that xn comes from a series; the question you asked is one about the property of the number xn.jens.w said:Yes, i thought of that at first, but it doesn't help in this case since x_{n}-L can be either positive or negative at all points, or alternating, depending on what series x_{n} is a part of. So based on that, i can't exclude one of the cases via the definition.
Ray Vickson said:If x >= L then x > L-ε (ε>0). So, just look at the case where x < L (assuming |x-L| < ε).
RGV
HallsofIvy said:As I am sure you know, |x|= x if x\ge 0, and |x|= -x if x< 0. So if x_n- L< 0, then |x_n- L|= -(x_n- L)= L- x_n< \epsilon so that -x_n< -L+ \epsilon and, multiplying boty sides by -1, x_n> L- \epsilon. Of course, if x_n- L\ge 0 then x_n\ge L and, since \epsilon> 0, L> L- \epsilon so x_n> L-\epsilon.
In either case, x_n> L- \epsilon.
Hurkyl said:It doesn't matter that xn comes from a series; the question you asked is one about the property of the number xn.
And besides, in a proof by cases you don't exclude a cases: you consider all of them. (in this case, only 2)
